http://forum.gsmhosting.com/vbb/f970...oader-2224548/ Possibly different phone model. Please post here complete Model Name and Number from back label and Software info from Settings. We will try to update loader for this phone as soon as possible. Br, Ultimate Multi Tool |
May be this is y55s 3 gb ram phone |
is there any way to boot this phone? |
superb umt team....the big update blast every time....thanku team |
dont worry umt team r best one they will find loader for this phone. |
umt team sir plz add meizu m2 user lock reset................... |
where do i found serial*.umtkey to update my card. |
can't remove or Disable mi 5 acc lock Operation : Disable Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1709400 [8996] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8996.ufl]... Done Executing Loader... Failed! Wrong Loader? Please select CPU manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 |
You need to try again and make sure using good quality cable, back usb port etc. Also make sure its Mi5, not other variant. You may also contact me on Skype. Br, Ultimate Multi Tool |
Its great update umt team it solve Noghat v7.0 moto G4 and moto G4 Plus Realy Thanks Team |
sir plz add mtk flasher |
forbidden application 03 detected ...................solution ? |
Remove C:\Windows\System32\drivers\npf.sys or rename it. Reboot pc. Br, Ultimate Multi Tool |
Oppo F3 Plus (OPPO CPH1613) Oppo F3 Plus Fingerprint Password Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009900 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 Operation : Format FS Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009900 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 |
please add Huawei fastboot mode flashing with update.app and remove frp w/o bootloader unlock. Need This Support in **mi latest update disable mi account support. **meizu unlock **improve QcFire Auto Detect Cpu **Mtk Module Read Flash Write Flash and Format **Mtk Secure boot cpu Thanks in Advanced. |
