Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-15-2017, 15:49   #16 (permalink)
Member: 2418156
Sonork: 1677163
Thanks Meter: 16
Dear sir i have a big problem i have 3 pic of redmi 3s prime problem are same pattern lock after factory reset done pattern lock remove but ask for mi ac main problem is both 3 set not connect when i press vol-+vol+ at same time but in fast boot connected properly and work only vol-+vol+ method not work volume key working fine please help me hanks
Old 05-15-2017, 16:06   #17 (permalink)
Member: 2310475
Thanks Meter: 61
Great team great update , love you
i need moto imei repair solution plz add ...........
i am requested many times plz plz
Old 05-15-2017, 16:30   #18 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 8,912
Use EDL cable or TP.
For further details, please use search.
Br,
Ultimate Multi Tool
Old 05-15-2017, 18:29   #19 (permalink)
Member: 2258056
Umt can remove Lenovo k6 note frp ?
Old 05-15-2017, 19:20   #20 (permalink)
U.M.T's Avatar
Member: 2465108
Thanks Meter: 8,912
If it is Qualcomm and can enter download mode, then yes.
Br,
Ultimate Multi Tool
The Following User Says Thank You to U.M.T For This Useful Post:
Old 05-15-2017, 19:22   #21 (permalink)
Member: 2007622
Sonork: 100.1674569
Thanks Meter: 8
Please any solution for Xiomi mimax pro mi account activate after disable when connect to wifi !
Old 05-16-2017, 05:49   #22 (permalink)
Member: 2470369
Thanks Meter: 16
Msm 8976pro and msm 8976 are same...?
Because i want to repair imei of samsung c900f (c9 pro)
Is that plssible to do that with selecting msm8976..?
Pls reply umt team
Pls..
Old 05-16-2017, 05:56   #23 (permalink)
U.M.T's Avatar
Member: 2465108
Thanks Meter: 8,912
If you can put Samsung in EDL, then yes, you may try.
I really not found any samsung device entering EDL.
About IMEI repair, Generic Qualcomm and samsung are really very different.
Br,
Ultimate Multi Tool
Old 05-16-2017, 07:29   #24 (permalink)
Member: 360614
Thanks Meter: 62
OMG Non-Stop Update...UMT is on fire....great..
Old 05-16-2017, 09:00   #25 (permalink)
Member: 2470369
Thanks Meter: 16
Br,
Ultimate Multi Tool
Sir is that possible to repair imei of samsung c900f with umt...?
Can u add the feature of samsung qualcomm support?
Old 05-16-2017, 10:03   #26 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 515
It is already in GSM Module.
Br,
Ultimate Multi Tool
GSM Module some phone supported.
Need supported qualcomm cpu universal imei repair
Old 05-16-2017, 10:41   #27 (permalink)
U.M.T's Avatar
Member: 2465108
Thanks Meter: 8,912
Universal method is that we have supported.
Other vendors use customize method, like Samsung Huawei etc who have added certificate or other layer of security.
Br,
Ultimate Multi Tool
Old 05-16-2017, 15:55   #28 (permalink)
.::RanjitSinh::.'s Avatar
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
Added Loader for Vivo Y55
- Incase of Vivo Y55, please untick Auto and select 8937_4 manually.
Br,
Ultimate Multi Tool
[/FONT][/COLOR]
still not booting vivo y55
Operation : Read Firmware
Checking for existing devices... Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM58)
Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2
Connecting to phone... OK
Waiting for response... OK
Init Handshake Sequence... OK
Hardware ID : E1600500 [8917] 00000000
Initializing Protocol... OK
Preparing Firehose Loader... Done
Sending Loader [8937_4..ufl]... Write Error!
Please use correct loader and check USB port / cable.
Module Ver. 0.9
Old 05-16-2017, 16:02   #29 (permalink)
Member: 517102
Sonork: 100.1601229
Thanks Meter: 199
with 8917 loader...
Sending Loader [8917.ufl]... Write Error!
Module Ver. 0.9
Old 05-16-2017, 19:36   #30 (permalink)
Member: 2653615
Sonork: 100.1675715
Thanks Meter: 15
Ultimate Multi Tool Team
Please Add Huawei FRP Reset
Thank You...
Page generated in 0.40311 seconds with 7 queries
