05-16-2017, 19:56 | #31 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
http://forum.gsmhosting.com/vbb/f970...oader-2224548/ Possibly different phone model. Please post here complete Model Name and Number from back label and Software info from Settings. We will try to update loader for this phone as soon as possible. Br, Ultimate Multi Tool | |
05-17-2017, 07:10 | #33 (permalink) | |
No Life Poster Join Date: May 2007 Location: Gujarat,India
Member: 517102 Status: Offline Sonork: 100.1601229 Thanks Meter: 199 | Quote:
is there any way to boot this phone? | |
05-18-2017, 20:17 | #38 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Aurangabad,Murshidabad,W.B. Age: 36
Member: 911173 Status: Offline Sonork: 1648990 Thanks Meter: 20 | can't remove or Disable mi 5 acc lock Operation : Disable Mi Account Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1709400 [8996] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8996.ufl]... Done Executing Loader... Failed! Wrong Loader? Please select CPU manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 |
05-19-2017, 07:49 | #39 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You need to try again and make sure using good quality cable, back usb port etc. Also make sure its Mi5, not other variant. You may also contact me on Skype. Br, Ultimate Multi Tool |
05-21-2017, 14:28 | #44 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | Oppo F3 Plus (OPPO CPH1613) Oppo F3 Plus Fingerprint Password Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM56) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009900 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 Operation : Format FS Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009900 [8976] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8976.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 0.9 |
05-22-2017, 10:16 | #45 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | please add Huawei fastboot mode flashing with update.app and remove frp w/o bootloader unlock. Need This Support in **mi latest update disable mi account support. **meizu unlock **improve QcFire Auto Detect Cpu **Mtk Module Read Flash Write Flash and Format **Mtk Secure boot cpu Thanks in Advanced. |
