01-20-2018, 12:53 | #63 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello. First of all write what model and Brand want flash in "FASTBOOT". Procedure is easy, Huawei, for example: Quote:
The Following User Says Thank You to allumts For This Useful Post: |
01-20-2018, 15:58 | #66 (permalink) | |
Crazy Poster Join Date: Jan 2018 Location: india,kerala
Member: 2801980 Status: Offline Thanks Meter: 2 | Quote:
01-20-2018, 17:56 | #67 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Where you read that you need to decrypt for FRP? For pattern, PIN, or password on encrypted device, better just format. Br, Ultimate Multi Tool |
01-21-2018, 13:27 | #75 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | OPPO A37f [msm8916] Pattern Read Done Smothly ================================ Log: Code: Operation : Read Pattern Lock Checking for existing devices...Found Port : COM4 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8916_014.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8916, eMMC, 16 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A37f [msm8916] Software : A37fEX_11_171008, 1480422943 [Sun Oct 8 17:26:49 CST 2017] Android Ver. : 5.1.1 USERDATA : Normal Reading Pattern Data...Done Pattern : 758649 Operation Finished. Module Ver. 1.5 |
The Following User Says Thank You to mcclinic For This Useful Post: |
