03-24-2017, 14:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | 2016002 mi max imei repair solution umt all method not work on this phone plz master help me logo is here Port : COM53 : Qualcomm Diagnostics Interface 3197 (COM53) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [QCOM Advance] Opening Port... OK Reading Phone Information... OK Compile : Dec 12 2016 19:23:28 Release : Aug 29 2016 04:00:00 Hw Ver. : 8976.gen Build : TA.2.1.c4-00013-1212_1915_a94f291 IMEI [1] : 111111111111111 IMEI [2] : 222222222222222 Method : QCOM Advance Preparing Data... Unsupported Firmware! Operation Finished. Elapsed Time: 00:04 [Module Ver. 3.6] Port : COM53 : Qualcomm Diagnostics Interface 3197 (COM53) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [NV Method] Opening Port... OK Reading Phone Information... OK Compile : Dec 12 2016 19:23:28 Release : Aug 29 2016 04:00:00 Hw Ver. : 8976.gen Build : TA.2.1.c4-00013-1212_1915_a94f291 IMEI [1] : 111111111111111 IMEI [2] : 222222222222222 Method : NV Method Writing IMEI 1 [861116034376568]... Failed! Read Only! Writing IMEI 2 [861116034378796]... Failed! Read Only! Operation Failed. Elapsed Time: 00:04 [Module Ver. 3.6] Port : COM53 : Qualcomm Diagnostics Interface 3197 (COM53) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [EFS Method] Opening Port... OK Reading Phone Information... OK Compile : Dec 12 2016 19:23:28 Release : Aug 29 2016 04:00:00 Hw Ver. : 8976.gen Build : TA.2.1.c4-00013-1212_1915_a94f291 IMEI [1] : 111111111111111 IMEI [2] : 222222222222222 Method : EFS Method Writing IMEI 1 [861116034376568]... OK Writing IMEI 2 [861116034378796]... OK Rebooting Phone... Done Please reboot maunally if does not reboot automatically. Operation Finished. Elapsed Time: 00:04 [Module Ver. 3.6] Port : COM53 : Qualcomm Diagnostics Interface 3197 (COM53) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [UMT Method [1]] Opening Port... OK Reading Phone Information... OK Compile : Dec 12 2016 19:23:28 Release : Aug 29 2016 04:00:00 Hw Ver. : 8976.gen Build : TA.2.1.c4-00013-1212_1915_a94f291 IMEI [1] : 111111111111111 IMEI [2] : 222222222222222 Method : UMT Method [1] Preparing Data... Done Writing IMEI 1 [861116034376568]... Done Writing IMEI 2 [861116034378796]... Done Rebooting Phone... Done Please reboot maunally if does not reboot automatically. Operation Finished. Elapsed Time: 00:08 [Module Ver. 3.6] Port : COM53 : Qualcomm Diagnostics Interface 3197 (COM53) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [UMT Method [2]] Opening Port... OK Reading Phone Information... OK Compile : Dec 12 2016 19:23:28 Release : Aug 29 2016 04:00:00 Hw Ver. : 8976.gen Build : TA.2.1.c4-00013-1212_1915_a94f291 IMEI [1] : 111111111111111 IMEI [2] : 222222222222222 Method : UMT Method [2] Writing IMEI 1 [861116034376568]... Failed Writing IMEI 2 [861116034378796]... Failed Operation Failed. Elapsed Time: 00:04 [Module Ver. 3.6] i want to knw how can i done ?????????????????????? |
03-26-2017, 07:38 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try to make QCN Backup and then reset EFS. After reset restore qcn and repair imei to original one written on back sticker. Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
03-26-2017, 10:58 | #3 (permalink) |
Banned Join Date: Jan 2015 Location: EARTH Age: 39
Member: 2332823 Status: Offline Sonork: 100.1662161:modern-mobile Thanks Meter: 463 | Code: Port : ADB Interface Baud Rate : Not Applicable Device : Qualcomm Android Operation : Reset EFS Searching for Device... Found Model : MI MAX Version : 6.0.1 Hardware : qcom Baseband : A.2.1.c4-00013-1130_1723_6edc2e5 CPU : arm64-v8a SIM Card : ABSENT,ABSENT Type : Unknown MEID(1) : Null/Empty Root : Rooted Gettting Partition Data... Not Found Creating EFS Backup (zip)... Pull Err! Operation Failed. Elapsed Time: 00:14 [Module Ver. 3.6] Log Saved to Logs\170326_152523.log |
03-27-2017, 16:22 | #4 (permalink) | |
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | i hve done but need qcn Quote:
Last edited by aryanmobile1989; 03-27-2017 at 16:25. Reason: i forget upload pic | |
03-27-2017, 17:34 | #5 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | 1 power on the phone and enable usb debugging 2 check phone rotted or not? if rotted then (enable diag) 3 Scan And Select correct comport diag 4 use qualcomm imei repair method. (QCOM ADVANCE) or (NV METHOD) (follow UMT) |
The Following User Says Thank You to raisalina For This Useful Post: |
03-27-2017, 17:46 | #6 (permalink) | |
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | thx to umt for help Quote:
here is qcn file https://www.4shared.com/rar/cvXqhbyqca/mi-max.html | |
The Following 3 Users Say Thank You to aryanmobile1989 For This Useful Post: |
01-02-2018, 13:54 | #12 (permalink) | |
Insane Poster Join Date: Nov 2013 Location: pakistan
Member: 2069200 Status: Offline Sonork: 100.1624776 Thanks Meter: 24 | Quote:
02-24-2018, 18:01 | #14 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 218901 Status: Offline Thanks Meter: 64 | Port : ADB Interface Baud Rate : Not Applicable Device : Qualcomm Android Operation : Reset EFS Searching for Device... Found Model : MI MAX Version : 6.0.1 Hardware : qcom Baseband : A.2.1.c4-00013-1201_1759_645654c CPU : arm64-v8a SIM Card : ABSENT,ABSENT Type : Unknown MEID(1) : Null/Empty Root : Rooted Gettting Partition Data... Not Found Creating EFS Backup (zip)... Pull Err! Operation Failed. Elapsed Time: 00:16 [Module Ver. 4.8] |
