03-30-2018, 11:32 | #61 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Bardibas Age: 31
Member: 2670396 Status: Offline Thanks Meter: 125 | Operation : Read Firmware Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00000000 OPK_DATA : 4AE06279352ED82F2509B1A78E471D63C3C4EE43DFF1C16EC9 F21AAC841F45C1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8937_ddr.mbn]...Write Error! Please use correct loader and check USB port / cable. Module Ver. 2.0 |
03-30-2018, 18:28 | #62 (permalink) |
Freak Poster Join Date: Nov 2017
Member: 2775355 Status: Offline Thanks Meter: 177 | I need this file can you upload please. [QUOTE=Conejo27;13044193]Device : Coolpad 3632A Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00004800 OPK_DATA : 5D48DE7B2B9D1360F74C1CD1DAB44807D69E084C807C89F93E C70EA553DAADCD Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...OK Device : Coolpad Coolpad 3632A [msm8937] Software : 7.1.108.56.P2.170511.NMF26F.MPCS, 108560743 [Thu May 11 15:43:32 CST 2017] Android Ver. : 7.1.1 Patch Level : 2017-04-01 Reading [modem]...Done Reading [sbl1]...Done Reading [sbl1bak]...Done Reading [rpm]...Done Reading [rpmbak]...Done Reading [tz]...Done Reading [tzbak]...Done Reading [devcfg]...Done Reading [devcfgbak]...Done Reading [dsp]...Done Reading [sec]...Done Reading [aboot]...Done Reading [abootbak]...Done Reading [boot]...Done Reading [recovery]...Done Reading [cache]...Done Reading [persist]...Done Reading [misc]...Done Reading [mdtp]...Done Reading [cmnlib]...Done Reading [cmnlibbak]...Done Reading [cmnlib64]...Done Reading [cmnlib64bak]...Done Reading [keymaster]...Done Reading [keymasterbak]...Done Reading [system]...Done Reading [userdata]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : C:\UMTool\QcFire\Read\Coolpad_Coolpad 3632A_7.1.108.56.P2.170511.NMF26F.MPCS_2017-04-01\ Operation Finished. Module Ver. 2.0[/QUOTE Stuck on log Coolpad 3632a |
03-31-2018, 17:20 | #63 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Republica Dominicana
Member: 2653449 Status: Offline Thanks Meter: 58 | flash coolpad cp3636 7.0 done Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00004800 OPK_DATA : 5D48DE7B2B9D1360F74C1CD1DAB44807D69E084C807C89F93E C70EA553DAADCD Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [modem_0.img] -> [modem]...Done Writing [sbl1_0.img] -> [sbl1]...Done Writing [sbl1bak_0.img] -> [sbl1bak]...Done Writing [rpm_0.img] -> [rpm]...Done Writing [rpmbak_0.img] -> [rpmbak]...Done Writing [tz_0.img] -> [tz]...Done Writing [tzbak_0.img] -> [tzbak]...Done Writing [devcfg_0.img] -> [devcfg]...Done Writing [devcfgbak_0.img] -> [devcfgbak]...Done Writing [dsp_0.img] -> [dsp]...Done Writing [sec_0.img] -> [sec]...Done Writing [splash_0.img] -> [splash]...Done Writing [aboot_0.img] -> [aboot]...Done Writing [abootbak_0.img] -> [abootbak]...Done Writing [boot_0.img] -> [boot]...Done Writing [recovery_0.img] -> [recovery]...Done Writing [cache_0.img] -> [cache]...Done Writing [persist_0.img] -> [persist]...Done Writing [misc_0.img] -> [misc]...Done Writing [mdtp_0.img] -> [mdtp]...Done Writing [cmnlib_0.img] -> [cmnlib]...Done Writing [cmnlibbak_0.img] -> [cmnlibbak]...Done Writing [cmnlib64_0.img] -> [cmnlib64]...Done Writing [cmnlib64bak_0.img] -> [cmnlib64bak]...Done Writing [keymaster_0.img] -> [keymaster]...Done Writing [keymasterbak_0.img] -> [keymasterbak]...Done Writing [system_0.img] -> [system]...Done Writing [gpt_main0.bin] -> [gpt_main0] ...Done Writing [gpt_back0.bin] -> [gpt_back0] ...Done Applying Patches................Done Resetting device...Done Operation Finished. Module Ver. 2.0 |
The Following User Says Thank You to Conejo27 For This Useful Post: |
04-04-2018, 05:05 | #65 (permalink) | |
Insane Poster Join Date: Apr 2016
Member: 2560333 Status: Offline Thanks Meter: 25 | plz add spd cpu and mtk 7.0 Support plz Quote:
\ \ \ \[ plz add spd cpu and mtk 7.0 Support plz | |
04-05-2018, 02:22 | #67 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | ZTE U9180 NOT SUPPORTED PLZ SUPPORT IT Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1508000 [8x26] 00000000 OPK_DATA : 777F076CD8FBCB291F4A544FDC16D09323E61E57C63C2B7006 2DCBDDF61B5EC8 Initializing Protocol...OK Preparing Firehose Loader...Done Sending Loader [8x26_006.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
04-08-2018, 13:37 | #68 (permalink) |
Temporary banned !! Join Date: Jun 2014 Location: Tirumala,Tirupathi
Member: 2199277 Status: Offline Sonork: 100.1678358 Thanks Meter: 167 | https://ibb.co/mfHLZx not opend my umt box |
04-09-2018, 13:51 | #69 (permalink) |
Freak Poster Join Date: Dec 2013 Location: India
Member: 2077370 Status: Offline Sonork: 100.1616788 Thanks Meter: 268 | redminote 5 pro mi account done info Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [redmi note 5 pro.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.6.0.NEIMIEK [Thu Mar 15 21:57:01 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Operation Finished. Module Ver. 2.0 account remove Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM19) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [redmi note 5 pro.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.6.0.NEIMIEK [Thu Mar 15 21:57:01 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. Operation Finished. Module Ver. 2.0 Last edited by skgrxl; 04-09-2018 at 13:57. |
The Following User Says Thank You to skgrxl For This Useful Post: |
04-14-2018, 08:18 | #70 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Redmi 5 Plus mi accaount reset done Redmi 5 Plus mi accaount reset done Quote:
The Following User Says Thank You to nahidroman For This Useful Post: |
04-15-2018, 06:34 | #71 (permalink) |
No Life Poster Join Date: Oct 2013
Member: 2050872 Status: Offline Thanks Meter: 658 | |
04-17-2018, 17:12 | #72 (permalink) |
Registered User Join Date: Nov 2001 Location: close to your mind Age: 53
Member: 7457 Status: Offline Thanks Meter: 21 | Coolpad cp3636a criket, blinking its lock phone, i tried diag mode to enable with umt tool, now its blinking, i need to flash to recover, my bad luck no flash file available. If any one can get be full backup flash which will enable me bring alaive, or flash link pls. Thanks. |
04-18-2018, 09:00 | #74 (permalink) |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | OPPO A 37F READ PATERN DONE SMOOTHLY [IMG]<a href="http://www.freeimagehosting.net/commercial-photography/"><img src="https://i.imgur.com/58aZ8HX.png" alt="Commercial Photography"></a>[/IMG] Last edited by naveedsialkoti; 04-18-2018 at 09:05. |
