03-24-2018, 17:01 | #47 (permalink) |
Freak Poster Join Date: Nov 2013 Location: spian
Member: 2062154 Status: Offline Sonork: 123321 Thanks Meter: 134 | PLZ HELP MI ACCOUNT RESET DEVIS IS LOKED AFTER CONECT TO WIFI peration : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM11) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8937_003.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5A [msm8937] Software : N2G47H, 8.2.1 [Thu Feb 1 00:50:55 CST 2018] Android Ver. : 7.1.2 Patch Level : 2018-01-01 Reading Data... |
03-27-2018, 01:19 | #52 (permalink) | |
Freak Poster Join Date: Nov 2016 Location: Republica Dominicana
Member: 2653449 Status: Offline Thanks Meter: 58 | hi bro need Quote:
Please add direct unlocking, coolpad 3632A AND COOLPAD 3636A PLEASE? | |
03-27-2018, 04:19 | #53 (permalink) | |
Member: 2653449 Status: Offline Thanks Meter: 58 | Read firmaware coolpad cp3636a 7.0 done umt box Quote:
Device : Coolpad CP3636A Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00004800 OPK_DATA : 5D48DE7B2B9D1360F74C1CD1DAB44807D69E084C807C89F93E C70EA553DAADCD Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...OK Device : Coolpad cp3636a [msm8937] Software : 09303170228, 093031423 [Tue Feb 28 22:23:08 CST 2017] Android Ver. : 7.0 Patch Level : 2017-02-01 Reading [modem]...Done Reading [sbl1]...Done Reading [sbl1bak]...Done Reading [rpm]...Done Reading [rpmbak]...Done Reading [tz]...Done Reading [tzbak]...Done Reading [devcfg]...Done Reading [devcfgbak]...Done Reading [dsp]...Done Reading [sec]...Done Reading [splash]...Done Reading [aboot]...Done Reading [abootbak]...Done Reading [boot]...Done Reading [recovery]...Done Reading [cache]...Done Reading [persist]...Done Reading [misc]...Done Reading [mdtp]...Done Reading [cmnlib]...Done Reading [cmnlibbak]...Done Reading [cmnlib64]...Done Reading [cmnlib64bak]...Done Reading [keymaster]...Done Reading [keymasterbak]...Done Reading [system]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : C:\UMTool\QcFire\Read\Coolpad_cp3636a_09303170228_ 2017-02-01\ Operation Finished. Module Ver. 2.0 | |
The Following 2 Users Say Thank You to Conejo27 For This Useful Post: |
03-27-2018, 05:54 | #55 (permalink) | |
Member: 2653449 Status: Offline Thanks Meter: 58 | Read firmaware coolpad 3632A Done UMT QcFire v2.0 Quote:
Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00004800 OPK_DATA : 5D48DE7B2B9D1360F74C1CD1DAB44807D69E084C807C89F93E C70EA553DAADCD Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8917_009.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...OK Device : Coolpad Coolpad 3632A [msm8937] Software : 7.1.108.56.P2.170511.NMF26F.MPCS, 108560743 [Thu May 11 15:43:32 CST 2017] Android Ver. : 7.1.1 Patch Level : 2017-04-01 Reading [modem]...Done Reading [sbl1]...Done Reading [sbl1bak]...Done Reading [rpm]...Done Reading [rpmbak]...Done Reading [tz]...Done Reading [tzbak]...Done Reading [devcfg]...Done Reading [devcfgbak]...Done Reading [dsp]...Done Reading [sec]...Done Reading [aboot]...Done Reading [abootbak]...Done Reading [boot]...Done Reading [recovery]...Done Reading [cache]...Done Reading [persist]...Done Reading [misc]...Done Reading [mdtp]...Done Reading [cmnlib]...Done Reading [cmnlibbak]...Done Reading [cmnlib64]...Done Reading [cmnlib64bak]...Done Reading [keymaster]...Done Reading [keymasterbak]...Done Reading [system]...Done Reading [userdata]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : C:\UMTool\QcFire\Read\Coolpad_Coolpad 3632A_7.1.108.56.P2.170511.NMF26F.MPCS_2017-04-01\ Operation Finished. Module Ver. 2.0 | |
The Following 3 Users Say Thank You to Conejo27 For This Useful Post: |
