07-23-2017, 09:43 | #31 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
If yes, then update card should work just fine. If not, then issue with your internet connection. Try to use proxy. Br, Ultimate Multi Tool | |
The Following User Says Thank You to U.M.T For This Useful Post: |
07-23-2017, 09:46 | #32 (permalink) | |
Its really an old news that IMEI realted operations are no available in Indian Version. If you still can not understand, you better find a way yourself. Br, Ultimate Multi Tool | |
07-23-2017, 09:51 | #34 (permalink) |
Insane Poster Join Date: May 2013 Location: Karouli Raj. (India)
Member: 1934112 Status: Offline Sonork: 100.1614651 Thanks Meter: 10 | Please check following before update: - You must have working internet connection. - Date and time must be correct on your PC. - Antivirus and/or Firewall is disabled. - Only UMT Box/Dongle is connected to your PC. - All other Dongles/Boxes are disconnected. When you are ready, click on Update Card to continue... Please use latest version software to Update Card. |
07-23-2017, 09:52 | #35 (permalink) |
Member: 1934112 Status: Offline Sonork: 100.1614651 Thanks Meter: 10 | v2 not work update card failed, internet connection and other things ok ============================================ Please check following before update: - You must have working internet connection. - Date and time must be correct on your PC. - Antivirus and/or Firewall is disabled. - Only UMT Box/Dongle is connected to your PC. - All other Dongles/Boxes are disconnected. When you are ready, click on Update Card to continue... Failed to connect! Please check internet connection. |
07-23-2017, 09:59 | #36 (permalink) | |
Freak Poster Join Date: Sep 2006
Member: 360614 Status: Offline Thanks Meter: 63 | Quote:
here you go brother, this is international version https://www.4shared.com/photo/1DpF22...43221__1_.html | |
07-23-2017, 10:10 | #38 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | uart connect in umnt box while frp process what if we have umt dongle..??? no box can we connect other box as intwrface to remove frp via uart method..??? |
07-23-2017, 11:08 | #41 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,245 | Quote:
not have? must buy an ftdi box to use uart solution or buy uart cable from smart gsm | |
07-23-2017, 11:22 | #42 (permalink) | |
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | Quote:
thanx sir.. i have 2-3 box which can used for interface i just ask bcz i think its owrk only with only umt box interface...sooo also a small requst if possible.. add samsung pattern..password reset in usb mode like s7582 s7562 i tried some works..some not Last edited by mobi_soft; 07-23-2017 at 11:25. Reason: requst | |
07-23-2017, 11:32 | #44 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | To all who are facing issue with Card Update: Please download Fixed version from Google Drive Mirror. Uninstall old version and then install it and try to Update Card. https://drive.google.com/drive/folde...GM?usp=sharing Br, Ultimate Multi Tool |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
07-23-2017, 11:46 | #45 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | Finally update card problem solved Quote:
The Following User Says Thank You to mcclinic For This Useful Post: |
