01-26-2018, 12:11 | #47 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, Ultimate Multi Tool | |
01-26-2018, 21:05 | #52 (permalink) |
Junior Member Join Date: Feb 2016 Location: El Salvador
Member: 2529363 Status: Offline Thanks Meter: 0 | zte blade spark frp failed, still blocked after process Port : COM6 : ZTE Handset Diagnostic Interface (COM6) Baud Rate : 921600 Device : ZTE Blade Spark Z971 Operation : FRP Reset Opening Port... OK Reading Phone Information... OK Compile : Release : 15 201714: 48:28Apr Hw Ver. : 26 2017 Build : 9Z971V1.0.0B17 IMEI : 863727030198596 WIFI Addr : 000000000000 BT Addr : 000000000000 Resetting FRP Lock... OK Rebooting Device... OK You may now add your account and Reset Factory Setting Port Closed. Operation Finished. Elapsed Time: 00:03 [Module Ver. 4.8] |
01-26-2018, 21:43 | #53 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Does it not allow you to enter home screen? If so, please try with QcFire in EDL mode and post log. As already mentioned, new firmware may not allow this method to work. Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
01-26-2018, 23:28 | #54 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Colombia Age: 42
Member: 452143 Status: Offline Thanks Meter: 197 | Please add Network fix for Motorola XT1621 G4 please..... Port : Fastboot Inteface Baud Rate : Not Applicable Device : Motorola Operation : Network Fix Searching Network Interface... Found Connecting to device... OK Model : Moto G (4) Bootloader : 0xB106 Baseband : M8952_70004.04.03.32R ATHENE_LATAM_DSDS_CUST Build : Blur_Version.24.24.4.athene.retail.en.US Android : 6.0.1 Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1621 Boot Ver. : moto-msm8952-B1.06 Baseband : M8952_70004.04.03.32R ATHENE_LATAM_DSDS_CUST Software : Blur_Version.24.24.4.athene.retail.en.US IMEI : 35412807******* CPU : MSM8952 RAM : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F EMMC : 16GB SAMSUNG QE13MB RV=08 PV=07 FV=0000000000000007 Repair file missing! Please contact Support. Elapsed Time: 01:07 [Module Ver. 4.8] Log Saved to Logs\180126_172509.log Best regards |
01-27-2018, 08:11 | #58 (permalink) |
Freak Poster Join Date: Aug 2008 Location: philippines
Member: 841203 Status: Offline Thanks Meter: 44 | great work U.M.T X00LDA FRP SOLVE Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 39A21620 OPK_DATA : FDB379775FEB07C551EFBC01F78CD6ABAC99A2829E6F63768E 4491B32485B6E5 Initializing Protocol...OK Preparing Firehose Loader...Done Sending Loader [prog_emmc_firehose_qcfire.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8917, eMMC, 16 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : asus ASUS_X00LDA [msm8937] Software : NMF26F.WW_Phone-14.0400.1708.154-20170824, WW_Phone-14.0400.1708.154-20170824 [Thu Aug 24 20:16:26 CST 2017] Android Ver. : 7.1.1 Resetting FRP Lock......Done Operation Finished. Module Ver. 1.6 |
The Following User Says Thank You to cool_nash23 For This Useful Post: |
