Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 06-26-2018, 10:30   #16 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 7,110
Originally Posted by Achyut View Post
Oppo A71 imei repair not successful. SOFTWARE shows successful but imei still null. Please guide me the correct way
Operation : IMEI Reapir [META (New)]
Checking for existing META ports...
Found OPPO PreLoader USB VCOM (Android) (COM86) on COM86
Device Path : usb\vid_22d9&pid_0006&rev_????
Configuring Communication Channel...
Reading phone information...
CPU : MT6750
SW Ver. : MOLY.LR11.W1603.MD.TC16.JAD.SP.V6.P7
HW Ver. : OPPO6755_C66_N1_HW
IMEI1 : 151515151515151
IMEI2 : 151515151515151
Reading data from phone...
Repairing IMEI1 to 86551303251xxxx...
Repairing IMEI2 to 86551303251xxxx...
Syncing Data...
Operation Finished.
[Ver. 1.5]
BROM mode imei repair totally fail
Brand : Oppo
Model : A71 (CPH1717)
Operation : Repair IMEI
Please check if correct Platform/DA is selected
Disconnect Battery/Cable and Power On Phone.
[Ver. 1.5]
Read info is OK
Brand : Oppo
Operation : Read Info
Waiting for Phone in BROM Mode...
Connect Power Off phone within 30 secs...
Port : MediaTek USB Port (COM90)
Connected to BROM.
Sending Download Agent...
connect DA end stage: 2, enable DRAM in 1st DA: 0
Connecting to HighSpeed Port...
Waiting for HighSpeed Port..
Port : MediaTek DA USB VCOM (Android) (COM91)
Connected to Download Agent..
Driver: MediaTek Inc., USBSER.sys, 2.0.1136.0
Syncing with Target...
Reading Partition Table...
Reading Device Information...
Brand : OPPO
Manufacturer : OPPO
Model : CPH1717
Prod. Name : CPH1717
Device : CPH1717
Board : full_oppo6750_17351
Platform : mt6750
Android Ver. : 7.1.1
Display ID : CPH1717EX_11_A.02_170815
Patch Level : 2017-06-05
Userdata is ENCRYPTED
[Ver. 1.5]
Where we mentioned A71 imei repair?
Notice that comma ( , ) in update title.
Br,
UMT
Old 06-26-2018, 10:31   #17 (permalink)
U.M.T's Avatar
Member: 2465108
Thanks Meter: 7,110
Found OPPO PreLoader USB VCOM (Android) (COM27) on COM27
Device Path : usb\vid_22d9&pid_0006&rev_ffff
CPU : MT6750
SW Ver. : MOLY.LR11.W1603.MD.TC16.JAD.SP.V6.P13
Repairing IMEI1 to 354897008557044...
Repairing IMEI2 to 352793010325714...
Syncing Data...
Operation Finished.
[Ver. 1.5]
Read my previous post.
Br,
UMT
Old 06-26-2018, 10:52   #18 (permalink)
Member: 360614
Thanks Meter: 56
@ UMT, ok that was a misunderstanding in the title itself. "Another software" has already released the solution so i thought UMT brought it too. hope Umt team will bring the hot solution soon before it's cold
Old 06-26-2018, 11:57   #19 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 10,483
Grat update from a best team Keep it up.
Old 06-26-2018, 12:11   #20 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
UMT team nice work.
Please update MT6765
Old 06-26-2018, 14:21   #21 (permalink)
Member: 1050364
Thanks Meter: 106
Good update team
need vivo v5,v5s and more mtk device
Old 06-26-2018, 16:09   #22 (permalink)
worldlinkmobil's Avatar
Member: 1275418
Thanks Meter: 311
Good update team
Old 06-26-2018, 16:10   #23 (permalink)
Member: 2478540
Thanks Meter: 3
good update team thanks
Old 06-26-2018, 16:35   #24 (permalink)
Member: 2201381
Sonork: 100.1624971
Thanks Meter: 19
UMT Team plz update auto Connect MTK cpu....
The Following User Says Thank You to hashmi818 For This Useful Post:
Old 06-26-2018, 18:19   #25 (permalink)
Elgendi's Avatar
Member: 2821459
Thanks Meter: 262
Thanks UMT For New Update We Hope Add Oppo F7 FRP Read Info and Read Firmware Mediatek ..
The Following User Says Thank You to Elgendi For This Useful Post:
Old 06-26-2018, 18:36   #26 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,235
- Need support for encrypted device from v6 up
- Add Read Read/Dump Firmware
- Custom DA file select tab/box should be separate from Umt tool boot select...
Thanks for fix driver issue...
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 06-26-2018, 22:46   #27 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 330
Originally Posted by Fast Unlocking View Post
We are pleased to announce
UMTv2 / UMTPro
UltimateMTK v1.5
Innovative and Intelligent
Supported Functions:
- Read Info
- Reset FRP (For devices supporting this feature)
- Reset Locks (All Android Versions, Encrypted Userdata NOT Supported)
- Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported)
- Format FS
- Format FS (Advance)
- IMEI Repair in META / Boot Mode
- Backup NVRAM
- Restore NVRAM
- Reboot to META / FACTORY / FASTBOOT Mode
- Added Support for Helio CPU (MT6750, MT6755, MT6763 etc) - New
Added Support for Following Devices:
Oppo
- A71
- F3
YU
- Yureka YU5530
Preloader (PL) Selection Added
- If you connect phone in BROM, you may need to select preloader from Firmware.
Now it is more customizable, so if you have firmware, you remove FRP etc, without flashing etc.
Added Meizu IMEI Repair Option
- For procedure details, please select Meizu Mode, and read instructions in Log.
Removed Compatible Driver Check
- Now it can work with any MTK Driver Installed.
- If you get some error with your driver, please try to update drivers from UltimateMTK folder.
Added More DA in List
IMPORTANT
- Features introduced here will work on other devices too, which are not litsed here.
- User need to untick By Model checkbox to be able to select Platform manually.
- For manual work, just select DA and AUTH file if needed.
- Rest operations will work same.
Note : Some features are device/OS specific and may not work on all devices.
YOU FOUND SOME BUG?
- Please start a new thread, and post complete log (no cuts), and full screenshot.
- Follow your thread for instructions.
- When we tell you something, try it, and also post complete log with screenshot.
- If you post about anything NOT WORKING, WITHOUT LOG and SCREENSHOT, it will be useless and will be DELETED.
It Has Begun...
Keep Following Us...
Some Nice Updates Are On The Way...
SPECIAL THANKS TO OUR VALUABLE USERS FOR THEIR LOVE AND SUPPORT
WARNING :
ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI.
ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS.
WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE.
STATUTORY WARNING - READ CAREFULLY
Using International Edition of our software is prohibited by Indian Law.
We strictly advice you to use Indian Edition if you are in India.
If you use International Edition in India, it may cause legal action against you by local law enforcement agencies.
We will not be liable for any loss or damaged caused.
:: NO FAKE ADVERTISEMENT ::
:: NO FAKE UPDATES ::
:: NO FAKE WORLD'S FIRST ::
:: NO FAKE BLA BLA BLA ::
How to Download:
- Download UMT Support Access.
- Connect UMT Box/Dongle to PC and Run UMT Support Access.
- Download required Executable from Installer folder.
- Enjoy!
- Download Mirror - Google Drive and Mega.
PLEASE DO NOT POST OFF TOPIC HERE. ONLY POST REGARDING THIS UPDATE AND SUPPORTED MODELS. ANY OFF TOPIC POST WILL BE DELETED IMMEDIATELY.
FOR THANKS, USE ONLY THANKS BUTTON.
Possible activation? umt on nck?
Old 06-27-2018, 02:41   #28 (permalink)
amrMHF's Avatar
Member: 710690
Thanks Meter: 355
what about Encrypted Userdata are you planning to support it ??
Old 06-27-2018, 04:38   #29 (permalink)
otherboy123's Avatar
Member: 2006794
Sonork: 100.1664636
Thanks Meter: 82
What about Meizu M6 and can u update firmwares in UMT Support Area? Thanks
Sent from my MI 6 using Tapatalk
Old 06-27-2018, 05:31   #30 (permalink)
Member: 1677653
Thanks Meter: 1,235
Not possible,
Buy NCK BOX/DONGLE PRO & UMT BOX/DONGLE PRO
Page generated in 0.18359 seconds with 7 queries
