03-02-2021, 02:00 | #46 (permalink) |
Freak Poster Join Date: Oct 2012 Location: transilvania
Member: 1820429 Status: Offline Thanks Meter: 57 | Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM36) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Manufacturer : Xiaomi Android Ver. : 10 Display ID : QP1A.190711.020 Patch Level : 2020-07-01 Userdata is NOT ENCRYPTED Resetting Mi Account... - Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.2] |
The Following User Says Thank You to kervicell For This Useful Post: |
03-02-2021, 06:05 | #47 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: bohol/philippines
Member: 1634657 Status: Offline Sonork: not yet Thanks Meter: 54 | sir Quote:
03-02-2021, 15:30 | #50 (permalink) |
Insane Poster Join Date: Dec 2009 Location: shahkot
Member: 1195673 Status: Offline Sonork: rehanisrar Thanks Meter: 2 | problem Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Using Custom DA! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM4) Connect BROM failed: STATUS_SEC_AUTH_FILE_NEEDED(-1073545198) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.1] |
03-02-2021, 15:59 | #51 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Montenegro Podgorica Age: 46
Member: 216844 Status: Offline Thanks Meter: 30 | Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM7) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Manufacturer : Xiaomi Android Ver. : 10 Display ID : QP1A.190711.020 Patch Level : 2020-12-01 Userdata is NOT ENCRYPTED Resetting Mi Account... - Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.2] |
03-02-2021, 16:00 | #52 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | https://drive.google.com/file/d/1Tud...ew?usp=sharing Use this for UFS based phones like Xiaomi Note 8 Pro, Oppo F15 etc, and let us know. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
03-02-2021, 23:19 | #53 (permalink) |
Freak Poster Join Date: Mar 2009 Location: PUTIN HUYLO
Member: 998119 Status: Offline Thanks Meter: 90 | Redmi 6A Flash fail CPU : MT6765 Storage : EMMC Scatter : C:\cactus_\images\MT6765_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.2019-12-31.22:58 Waiting for Phone in BROM Mode... Connect Power Off phone now... Port : MediaTek USB Port (COM172) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Flashing Firmware... [0] WRITE TO PARTITION [ preloader ] Flashing Bootloader... [3] WRITE TO PARTITION [ recovery ] [17] WRITE TO PARTITION [ md1img ] [18] WRITE TO PARTITION [ spmfw ] [19] WRITE TO PARTITION [ scp1 ] [20] WRITE TO PARTITION [ scp2 ] [21] WRITE TO PARTITION [ sspm_1 ] [22] WRITE TO PARTITION [ sspm_2 ] [26] WRITE TO PARTITION [ vbmeta ] [27] WRITE TO PARTITION [ lk ] [28] WRITE TO PARTITION [ lk2 ] [29] WRITE TO PARTITION [ boot ] [30] WRITE TO PARTITION [ logo ] [31] WRITE TO PARTITION [ odmdtbo ] [32] WRITE TO PARTITION [ cust ] Flashing Failed! Disconnect cable and Power ON phone. |
03-03-2021, 04:06 | #56 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | No, but isn't it common thing to untick what cause failure while flashing and try again? Didn't you noticed such issue with Qualcomm phone ever? Btw, one user reported issue with latest firmware version, and he flashed MIUI 11 which caused this issue and then flashed with 10 successfully. Br, UMT |
03-03-2021, 04:08 | #57 (permalink) | |
Member: 1634657 Status: Offline Sonork: not yet Thanks Meter: 54 | Quote:
03-03-2021, 06:14 | #58 (permalink) |
Junior Member Join Date: May 2007
Member: 516424 Status: Offline Thanks Meter: 12 | Brand : Xiaomi Model : Redmi 9A Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM7) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Unable to read! Userdata is ENCRYPTED Resetting Mi Account... - Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.2] Reset Done. BUT not done |
03-03-2021, 06:22 | #59 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | realme c2 bootloop to recovery mode after reset Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek USB Port (COM322) on COM322 Device Path : \\?\usb#vid_0e8d&pid_0003#5&155d656&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found USB Serial Device (COM368) on COM368 Device Path : \\?\usb#vid_22d9&pid_0006#5&155d656&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Configuring Communication Channel... Retrying Connection... Found USB Serial Device (COM368) on COM368 Device Path : usb\vid_22d9&pid_0006&rev_???? Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.PIE.P22.PR2.TC16.SP.V1.P17 HW Ver. : OPPO_P0MP3_K62V1_64_BSP_HW Brand: Realme Model: RMX1941 Name: realme C2 Platform: MT6765 OEM Prod.: RMX1941 OEM Device: RMX1941 Build Date: Thu Jan 14 18:43:59 CST 2021 Display ID: RMX1941EX_11_A.32 OTA Version: RMX1941EX_11.A.32_0320_202101141821 Patch Level: 2021-01-05 Starting Safe Factory Reset... Reset success Operation finished [UltimateMTK Ver. 3.8] |
03-03-2021, 06:42 | #60 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
OR Do Format FS using Oppo A11K, but before that must Disable Auth. Br, UMT | |
