02-27-2021, 15:08 | #1 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | [27-02-21] UMTv2/UMTPro - UltimateMTK v3.8 - Disable Auth, Xiaomi Account Reset.... UltimateMTK v3.8 Supported functions: - Read Info - Reset FRP (For devices supporting this feature) - Reset Locks (All Android Versions, Encrypted Userdata NOT Supported) - Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported) - Format FS - Format FS (Advance) - IMEI Repair in META / Boot Mode - Backup NVRAM - Restore NVRAM - Reboot to META / FACTORY / FASTBOOT Mode - Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc) - Disable Lock / Restore Lock for Encrypted Userdata - Remove Lcoks for Encrypted Userdata for Vivo - Factory Reset in META Mode (Vivo, Oppo and others) - SafeFormat Option to let device format itself safely in recovery - Added Support for Helio X20 (MT6797) - Oppo/Realme Safe Factory Reset in META Mode - Added Disable Auth to disable SLA/DAA - New!!! - Added Mi Account Reset - New!!! Added Support for following chipsets: - MT6757D - MT6758 - MT6759 - MT6768 - MT6771 - MT6779 - MT6785 - MT6799 - MT6873 - MT8167 - MT8695 Added: IRIS - Tab G7100 Infinix - Note 7 (X690) - S5 Pro (X660) Jivi - Xtreme 1 Micromax - Q4311 Oppo - A5s (CPH1909) - A11k (CPH2083) Vivo - Y19 (PD1934F) - Y81i Xiaomi - Note 8 Pro - Note 9 - Redmi 6A - Redmi 9A - Redmi 9 Prime Added Disable Auth (SLA/DAA) - Supported Chipsets: - MT6261 - MT6572 - MT6580 - MT6582 - MT6735 - MT6737 - MT6739 - MT6755 - MT6757 - MT6761 - MT6763 - MT6765 - MT6768 - MT6771 - MT6785 - MT6799 - MT6873 - MT8127 - MT8163 - MT8173 - MT8695 - It will disable SLA and DAA in BROM Mode - You can perform any operation after Disable Auth without disconnecting device - Need to install libusb filter driver (Available on support) Thanks for this exploit goes to: - bkerler - chaosmaster - Dinolek It was almost impossible to make it without them! Added Mi Account Reset for Xiaomi Devices Added Oppo MTK OFP Extracter Updated Internal Libraries to newer version Special thanks to: - SINTO01 - azaz_ahamad - neyaz007 - nksonu_jobner - owais_a - raz007 - soulay Important - Features introduced may work on other devices too, which are not litsed here. - User needs to untick By Model checkbox to be able to select Platform manually. - For manual work, just select Platform and DA. - For new secured devices, you may need to select AUTH and/or Preloader. - Rest operations will work same. Note : Some features are device/OS specific and may not work on all devices. WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website |
The Following 50 Users Say Thank You to U.M.T For This Useful Post: |
02-27-2021, 15:36 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | How to install libusb filter driver for Bypass Auth: 1. Install libusb filter by running libusb-win32-devel-filter-1.2.6.0.exe from C:\UMTools\UltimateMTK\Drivers\ 2. Goto Start Menu > Libusb-Win32 > Filter Wizard 3. Select Install a driver option, click Next. 4. It will show you list of all devices you can install filter driver for. Select MTK USB Port and click Install. 5. You are done. Please note, that you don't need to disconnect phone once Disable Auth is done, and continue to required operation. Br, UMT Last edited by U.M.T; 02-27-2021 at 15:44. |
The Following 15 Users Say Thank You to U.M.T For This Useful Post: |
02-27-2021, 16:13 | #8 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oppo F5 Extract Done Code: Operation : Extract OPF Firmware OPF File : CPH1723_11_A.41_191120_21e8c378_EXP.ofp Project Info: 184434 Target CPU: 6763 Flash Type: emmc Extracting [DAA_AUTH_FILE] to [auth_sv5.auth]... Extracting [EFUSE_CONFIG] to [17031-efuse_oppo6763.xml]... Extracting [EFUSE_INI] to [Efuse.ini]... Extracting [Projectconfig.xml] to [Projectconfig.xml]... Extracting [all-in-one-signature.bin] to [all-in-one-signature.bin]... Extracting [boot] to [boot.img]... Extracting [cache] to [cache.img]... Extracting [img_list.txt] to [img_list.txt]... Extracting [lk] to [lk.bin]... Extracting [lk2] to [lk.bin]... Extracting [logo] to [logo.bin]... Extracting [md1dsp] to [md1dsp.img]... Extracting [md1img] to [md1rom.img]... Extracting [oppo_custom_17321] to [oppo_custom_17321.img]... Extracting [oppo_custom_17323] to [oppo_custom_17323.img]... Extracting [oppo_custom_17325] to [oppo_custom_17325.img]... Extracting [oppo_custom_17371] to [oppo_custom_17371.img]... Extracting [oppo_custom_17373] to [oppo_custom_17373.img]... Extracting [oppo_custom_17375] to [oppo_custom_17375.img]... Extracting [oppo_custom_17377] to [oppo_custom_17377.img]... Extracting [oppo_custom_17379] to [oppo_custom_17379.img]... Extracting [preloader] to [preloader_oppo6763_17031.bin]... Extracting [recovery] to [recovery.img]... Extracting [scatter] to [MT6763_Android_scatter.txt]... Extracting [spmfw] to [spmfw.bin]... Extracting [sspm_1] to [tinysys-sspm.bin]... Extracting [sspm_2] to [tinysys-sspm.bin]... Extracting [system] to [system.img]... Extracting [system.sig] to [system.sig]... Extracting [system_internal.sig] to [system_internal.sig]... Extracting [tee1] to [trustzone.bin]... Extracting [tee2] to [trustzone.bin]... Extracting [userdata] to [userdata.img]... Extracting [userdata.sig] to [userdata.sig]... Extracting [userdata_internal.sig] to [userdata_internal.sig]... Exracted to : E:\Extracted\ Operation Finished |
The Following 6 Users Say Thank You to Tanha0321 For This Useful Post: |
02-27-2021, 17:08 | #10 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,080 | Code: OPPO A1K Flash Done Ultimate MTK Tool Storage : EMMC Scatter : C:\Users\Salina\Desktop\A1k\New folder\Extracted\MT6765_Android_scatter.txt DA Version : MTK_AllInOne_DA_v3.3001.2019-06-26.13:07 Waiting for Phone in BROM Mode... Connect Power Off phone now... Port : MediaTek USB Port_V1633 (COM8) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Format Address : [0x0] - Size : [0x0] Format Succeeded. Executing Flashing Task... [0] WRITE TO PARTITION [ preloader ] Flashing Bootloader... [3] WRITE TO PARTITION [ recovery ] Flashing Firmware... [11] WRITE TO PARTITION [ vbmeta ] [21] WRITE TO PARTITION [ md1img ] [22] WRITE TO PARTITION [ spmfw ] [23] WRITE TO PARTITION [ scp1 ] [24] WRITE TO PARTITION [ scp2 ] [25] WRITE TO PARTITION [ sspm_1 ] [26] WRITE TO PARTITION [ sspm_2 ] [30] WRITE TO PARTITION [ lk ] [31] WRITE TO PARTITION [ lk2 ] [32] WRITE TO PARTITION [ boot ] [33] WRITE TO PARTITION [ logo ] [34] WRITE TO PARTITION [ dtbo ] [35] WRITE TO PARTITION [ tee1 ] [36] WRITE TO PARTITION [ tee2 ] [37] WRITE TO PARTITION [ odm ] write signature file. [ C:\Users\Salina\Desktop\A1k\New folder\Extracted\vendor.sig ] [38] WRITE TO PARTITION [ vendor ] write signature file. [ C:\Users\Salina\Desktop\A1k\New folder\Extracted\system.sig ] [39] WRITE TO PARTITION [ system ] [40] WRITE TO PARTITION [ cache ] write signature file. [ C:\Users\Salina\Desktop\A1k\New folder\Extracted\userdata.sig ] [41] WRITE TO PARTITION [ userdata ] Flashing Done. Disconnect cable and Power ON phone. |
The Following 9 Users Say Thank You to raisalina For This Useful Post: |
02-27-2021, 17:35 | #11 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | after reset Mi Account will it relock when connect to wifi Tx |
The Following 3 Users Say Thank You to sky_finder For This Useful Post: |
02-27-2021, 18:23 | #14 (permalink) | |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Quote:
Menu appeared without any MTK USB PORT option.. maybe because i installed it before?! any way I will test new version, thx UMT Team. | |
The Following User Says Thank You to boganice For This Useful Post: |
