05-27-2021, 22:46 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | [27-05-21] UMTv2/UMTPro UltimateMTK v4.3 - Redmi6/6A Both SIM Repair, Samsung FRP ... UltimateMTK v4.3 Supported functions: - Read Info - Reset FRP (For devices supporting this feature) - Reset Locks (All Android Versions, Encrypted Userdata NOT Supported) - Read Pattern (Android 5.x and earlier, Encrypted Userdata NOT Supported) - Format FS - Format FS (Advance) - IMEI Repair in META / Boot Mode - Backup NVRAM - Restore NVRAM - Reboot to META / FACTORY / FASTBOOT Mode - Added Support for Helio CPU (MT6750, MT6755, MT6763, MT6739 etc) - Disable Lock / Restore Lock for Encrypted Userdata - Remove Lcoks for Encrypted Userdata for Vivo - Factory Reset in META Mode (Vivo, Oppo and others) - SafeFormat Option to let device format itself safely in recovery - Added Support for Helio X20 (MT6797) - Oppo/Realme Safe Factory Reset in META Mode - Added Disable Auth to disable SLA/DAA - Added Mi Account Reset - Xiaomi IMEI Repair - NVRAM/NVDATA Format - META Reboot for SLA Enabled Devices - MTK One Click Function Added - Crash Preloader Added - Added More Options in MTK One Click - NEW!!! Added: MTK One Click - No need to select any model. - No need to select any DA/preloader. - Simply tick required options and execute. Added SLA/DAA Bypass for: - MT6753 - MT6795 - MT6797 Added More Options to MTK One Click - Format FS - Erase FS - Safe Format - Reset Locks (Vivo) - Reset Locks (Oppo) - Format Cache Added Patch Modem / NV Format (Redmi 6/6A) - Use this option to Repair Dual SIM on both phones - Patch and Format NVRAM in single click without flashing any eng firmware - After this function you need to Repair both IMEI using META Method (New) - If you encounter NV DATA CORRUPTED issue, please do this hardware modification Updated One Click FRP Reset to support Samsung Devices Added Format Cache Function - This option is specially useful for Oppo Phones stuck in Recovery Mode after Safe Reset Improved MTK One Click Functions - Now selecting multiple operations at once should work fine Added Mi Account Patch (Beta) - This is for test, may work or may not work at all Improved Oppo Unlock (Beta) - To test, first Unlock in BROM, and then repeat in META Improved Firmware Flash Function Tested Devices with MTK One Click: Huawei - Y3 (CRO-L22) - Y5 Prime (DRA-LX2) Ibrit - I7 Infinix - Hot 10 (X682C) - Hot 9 Play (X680F) - Smart HD 2021 (X612B) iTel - S21 LG - K10 (M250i) - K61 (LM-Q630EA) Leagoo - KIICAA Mix Lenovo - A5 (L18021) Meizu - M3s Micromax - IN 1b (E7533) Motorola - One Macro (XT2016-1) Nokia - 1 Plus (TA-1130) - 2.2 (TA-1183) - 2.3 (TA-1206) - 2.4 (TA-1277) Oppo - A11k - A12 (CPH2077) - A15 (CPH2185) - A15s (CPH2179) - A1k - A54 (CPH2239) - A5s (CPH1920) - A71 (CPH1717) - A94 (CPH2203) - F11 (CPH1911) - F15 (CPH2001) - F17 Pro (CPH2119) - F19 Pro (CPH2285) - F3 (CPH1609) - Reno 2F (CPH1989) - Reno 2Z (CPH1951) - Reno Z (CPH1979) - Reno4 Lite (CPH2125) - Realme 3 (RMX1825) - Realme 8 (RMX3085) - Realme C11 (RMX2185) Samsung - A10s (A107F) - M01s (M017F) Spice - F311 Tecno - Camon 12 (KC3) - Pouvoir 2 (LA7) - Spark 6 Air (KE6) - Spark 6 Go (KE5j) - Spark Go 2020 (KE5) - i3 Pro Vivo - S1 (PD1913F) - V11 (PD1813F) - Y11i (PD1813F) - Y12 (PD1901BF) - Y19 (PD1934F) - Y20 2021 (PD2034F) - Y20G (PD2066F) - Y30 (PD1987F) - Y81 (PD1732F) - Y83 Pro (PD1803F) - Y91c (PD1818HF) - Y91i (PD1818HF) Xiaomi - Redmi 6 - Redmi 6A - Redmi 9 - Redmi Note 8 Pro MTK One Click supports most phones regardless of Brand and Model Special Thanks to: - There are numerous users who helped us improve things this time. - It really seems impossible to name each and everyone. - Thank to each and every of them Important - Features introduced may work on other devices too, which are not litsed here. - User needs to untick By Model checkbox to be able to select Platform manually. - For manual work, just select Platform and DA. - For new secured devices, use Disable Auth, and select Preloader. - Rest operations will work same. Note : Some features are device/OS specific and may not work on all devices. WARNING : ESN / MEID / IMEI REPAIR IS INTENDED TO REPAIR ESN / MEID / IMEI TO ORIGINAL ONE WRITTEN ON PHONE BACK LABEL / BOX. WE DO NOT ENDORSE OR ENCOURAGE ESN / MEID / IMEI CHANGING. ITS ILLEGAL. USER IS SOLE RESPONSIBLE FOR ANY ILLEGAL ACTIVITY DONE WITH USE OF FEATURES PROVIDED IN OUR SOFTWARE, NOT LIMITED TO ESN / MEID / IMEI. ANY USER USING OUR SOFTWARE FOR ILLEGAL PURPOSE WILL BE SOLE RESPONSIBLE FOR HIS ACTS. WE CONDEMN USE OF OUR SOFTWARE FOR ANY ILLEGAL PURPOSE. Download using Support Access or Mirrors Official Website |
The Following 64 Users Say Thank You to Fast Unlocking For This Useful Post: |
05-28-2021, 02:13 | #4 (permalink) |
Freak Poster Join Date: Apr 2012 Location: Quatar Age: 37
Member: 1752305 Status: Offline Thanks Meter: 101 | Samsung A10F U8 Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM11 Port Name: MediaTek PreLoader USB VCOM_V1632 (Android) (COM11) Path: \\?\usb#vid_0e8d&pid_2000#6&220308a0&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM20 Port Name: MediaTek USB Port_V1632 (COM20) Path: \\?\usb#vid_0e8d&pid_0003#6&220308a0&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM20) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Thu Mar 25 09:27:15 KST 2021 Build Flavor : a10sxx-user Build Desc. : a10sxx-user 10 QP1A.190711.020 A107FXXU8BUC2 release-keys Android Ver. : 10 Display ID : QP1A.190711.020.A107FXXU8BUC2 Patch Level : 2021-04-01 Platform : MT6765 Board : S96116CA1 Platform : mt6765 Platform : MT6765 Board : S96116CA1 Platform : mt6765 Userdata is NOT ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! - Resetting FRP[2]... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] Br, Tulang |
The Following 16 Users Say Thank You to lang-2 For This Useful Post: |
05-28-2021, 04:51 | #7 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 828 | Very Good Work UMT Team... Plz Add All Android Versions, Encrypted Pin,Pattren Unlock WithOut Loss Data . Thiths Will B Great. Thanks. |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
05-28-2021, 05:02 | #9 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Quote:
umt mtk modual is getting better and better day by day Last edited by djj007; 05-28-2021 at 05:10. | |
The Following 2 Users Say Thank You to djj007 For This Useful Post: |
05-28-2021, 05:22 | #10 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | UltimateMTK v4.3 Added: MTK One Click - No need to select any model. - No need to select any DA/preloader. - Simply tick required options and execute. Great update for umt users UMT Fast unlocking team Always rock Fast unlock team pleas add read firmware option in mtk chips |
05-28-2021, 08:18 | #12 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | mi account patch not work, redmi 6a Quote:
05-28-2021, 08:32 | #13 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,467 | Can you please try only Reset or with Patch also to see if things work. Because this error should not be there at first place. You may try once again also. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
05-28-2021, 08:42 | #14 (permalink) | |
Member: 1109337 Status: Offline Thanks Meter: 197 | Here is another one..... Quote:
