02-02-2019, 08:59 | #46 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Usbekistan Samarqand Bulung'ur
Member: 2154625 Status: Offline Thanks Meter: 76 | Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] Software : ZQL1711-vince-build-20181030213149, V10.0.4.0.OEGMIFH [Tue Oct 30 21:31:45 WIB 2018] Android Ver. : 8.1.0 Patch Level : 2018-11-01 USERDATA : Encrypted Disabling Android Locks...Failed If Locks are already disabled, please use Restore Locks option. Operation Failed. |
02-02-2019, 16:51 | #47 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Sorry, but it is the only way QC introduced to read QCN from device (as per my knowledge). Br, UMT | |
02-02-2019, 16:52 | #48 (permalink) | |
Br, UMT | |
02-02-2019, 16:55 | #49 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Downgrade is really tricky these days because of anti rollback. But you should be able to recover if you flash same firmware as was originally on device. Auth can not be calculated by thirdparty or bypass without special loader released from Mi. If someone claims so, he just making fun. Br, UMT |
02-04-2019, 16:49 | #52 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | First you have to connect in DIAG mode, means DIAG should be enabled and phone in Normal Mode. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
02-06-2019, 20:44 | #54 (permalink) |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | Please ADD These Models In Next Update Oppo Pattern Unlock & FRP Unlock: A3S (CPH1803) A5 (CPH1809) A7 (CPH1901) A83(2018) (CPH1729) F5 (CPH1723) F5 YOUTH (CPH1725) F7 (CPH1819) F9 (CPH1881) F9 PRO (CPH1823) REALME 1 (CPH1859) REALME 2 (RMX1805) REALME C1 (RMX1811) REALME 2 PRO (RMX1801) XIAOMI MI ACCOUNT: MI NOTE 5 PRO MI Y2 REDMI 6A REDMI 6 PRO REDMI 6 POCO F1 Note 6 pro MI 8 Thanks UMT Team |
02-11-2019, 18:34 | #58 (permalink) |
Junior Member Join Date: Jun 2006
Member: 290636 Status: Offline Thanks Meter: 3 | Great tool as always Any chance to bypass qualcomm trust zone I mean secure boot disable in bootloader Code: C:\Program Files\Minimal ADB and Fastboot>fastboot getvar all (bootloader) version:0.5 (bootloader) battery-soc-ok:yes (bootloader) battery-voltage:3966000 (bootloader) variant:MTP eMMC (bootloader) unlocked:yes (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) display-panel: (bootloader) off-mode-charge:0 (bootloader) charger-screen-enabled:0 (bootloader) max-download-size: 0x1fe00000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0xd0a379e00 (bootloader) partition-type:athena: (bootloader) partition-size:athena: 0x9600000 (bootloader) partition-type:reserved: (bootloader) partition-size:reserved: 0xa00000 (bootloader) partition-type:backup: (bootloader) partition-size:backup: 0xa00000 (bootloader) partition-type:apanic: (bootloader) partition-size:apanic: 0xa00000 (bootloader) partition-type:logdump: (bootloader) partition-size:logdump: 0x4000000 (bootloader) partition-type:dpo: (bootloader) partition-size:dpo: 0x2000 (bootloader) partition-type:msadp: (bootloader) partition-size:msadp: 0x40000 (bootloader) partition-type:apdp: (bootloader) partition-size:apdp: 0x40000 (bootloader) partition-type:survival: (bootloader) partition-size:survival: 0x4000000 (bootloader) partition-type:keymasterbak: (bootloader) partition-size:keymasterbak: 0x100000 (bootloader) partition-type:keymaster: (bootloader) partition-size:keymaster: 0x100000 (bootloader) partition-type:cmnlib64bak: (bootloader) partition-size:cmnlib64bak: 0x100000 (bootloader) partition-type:cmnlib64: (bootloader) partition-size:cmnlib64: 0x100000 (bootloader) partition-type:cmnlibbak: (bootloader) partition-size:cmnlibbak: 0x100000 (bootloader) partition-type:cmnlib: (bootloader) partition-size:cmnlib: 0x100000 (bootloader) partition-type:lksecappbak: (bootloader) partition-size:lksecappbak: 0x20000 (bootloader) partition-type:lksecapp: (bootloader) partition-size:lksecapp: 0x20000 (bootloader) partition-type:mcfg: (bootloader) partition-size:mcfg: 0x400000 (bootloader) partition-type:syscfg: (bootloader) partition-size:syscfg: 0x80000 (bootloader) partition-type:mdtp: (bootloader) partition-size:mdtp: 0x2000000 (bootloader) partition-type:dip: (bootloader) partition-size:dip: 0x100000 (bootloader) partition-type:mota: (bootloader) partition-size:mota: 0x80000 (bootloader) partition-type:limits: (bootloader) partition-size:limits: 0x8000 (bootloader) partition-type:oem: (bootloader) partition-size:oem: 0x4000000 (bootloader) partition-type:config: (bootloader) partition-size:config: 0x8000 (bootloader) partition-type:keystore: (bootloader) partition-size:keystore: 0x80000 (bootloader) partition-type:misc: (bootloader) partition-size:misc: 0x100000 (bootloader) partition-type:persist: (bootloader) partition-size:persist: 0x2000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:vendor: (bootloader) partition-size:vendor: 0x40000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0x100000000 (bootloader) partition-type:devinfo: (bootloader) partition-size:devinfo: 0x1000000 (bootloader) partition-type:recovery: (bootloader) partition-size:recovery: 0x4000000 (bootloader) partition-type:boot: (bootloader) partition-size:boot: 0x4000000 (bootloader) partition-type:abootbak: (bootloader) partition-size:abootbak: 0x1000000 (bootloader) partition-type:aboot: (bootloader) partition-size:aboot: 0x1000000 (bootloader) partition-type:splash: (bootloader) partition-size:splash: 0xb00000 (bootloader) partition-type:sec: (bootloader) partition-size:sec: 0x4000 (bootloader) partition-type:fsg: (bootloader) partition-size:fsg: 0x280000 (bootloader) partition-type:DDR: (bootloader) partition-size:DDR: 0x8000 (bootloader) partition-type:modemst2: (bootloader) partition-size:modemst2: 0x280000 (bootloader) partition-type:modemst1: (bootloader) partition-size:modemst1: 0x280000 (bootloader) partition-type:dsp: (bootloader) partition-size:dsp: 0x1000000 (bootloader) partition-type:devcfgbak: (bootloader) partition-size:devcfgbak: 0x40000 (bootloader) partition-type:devcfg: (bootloader) partition-size:devcfg: 0x40000 (bootloader) partition-type:tzbak: (bootloader) partition-size:tzbak: 0x200000 (bootloader) partition-type:tz: (bootloader) partition-size:tz: 0x200000 (bootloader) partition-type:rpmbak: (bootloader) partition-size:rpmbak: 0x80000 (bootloader) partition-type:rpm: (bootloader) partition-size:rpm: 0x80000 (bootloader) partition-type:sbl1bak: (bootloader) partition-size:sbl1bak: 0x80000 (bootloader) partition-type:sbl1: (bootloader) partition-size:sbl1: 0x80000 (bootloader) partition-type:ssd: (bootloader) partition-size:ssd: 0x2000 (bootloader) partition-type:fsc: (bootloader) partition-size:fsc: 0x400 (bootloader) partition-type:modem: (bootloader) partition-size:modem: 0x5400000 (bootloader) serialno:8c9507c5 (bootloader) kernel:lk (bootloader) product:MSM8953 all: finished. total time: 1.281s C:\Program Files\Minimal ADB and Fastboot> My device is Vivo V9 |
