05-17-2018, 09:47 | #3 (permalink) |
Junior Member Join Date: May 2018
Member: 2836815 Status: Offline Thanks Meter: 1 | account coming back after wifi Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 5X [msm8953] Software : QL1515-tiffany-build-20180121153811, V9.2.1.0.NDBCNEK [Sun Jan 21 15:38:02 CST 2018] Android Ver. : 7.1.2 Patch Level : 2017-12-05 Resetting FRP Lock......Done Operation Finished. Module Ver. 2.1 |
05-17-2018, 09:49 | #4 (permalink) |
Member: 2836815 Status: Offline Thanks Meter: 1 | stuck on logo after 2.2 Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 5X [msm8953] Software : QL1515-tiffany-build-20180121153811, V9.2.1.0.NDBCNEK [Sun Jan 21 15:38:02 CST 2018] Android Ver. : 7.1.2 Patch Level : 2017-12-05 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. Finalizing task...Done Operation Finished. Module Ver. 2.2 |
05-20-2018, 11:06 | #11 (permalink) |
Member: 2836815 Status: Offline Thanks Meter: 1 | flash done phone relocked after wifi Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Parsing Partition Entries...Done File not found for modem File not found for fsc File not found for ssd File not found for sbl1 File not found for sbl1bak File not found for rpm File not found for rpmbak File not found for tz File not found for tzbak File not found for devcfg File not found for devcfgbak File not found for dsp File not found for modemst1 File not found for modemst2 File not found for DDR File not found for fsg File not found for sec File splash.img loaded for splash File not found for aboot File not found for abootbak File boot.img loaded for boot File recovery.img loaded for recovery File not found for devinfo File system.img loaded for system File cache.img loaded for cache File persist.img loaded for persist File misc.img loaded for misc File not found for keystore File not found for config File not found for oem File not found for limits File not found for mota File not found for dip File mdtp.img loaded for mdtp File not found for syscfg File not found for mcfg File not found for lksecapp File not found for lksecappbak File not found for cmnlib File not found for cmnlibbak File not found for cmnlib64 File not found for cmnlib64bak File not found for keymaster File not found for keymasterbak File not found for apdp File not found for msadp File not found for dpo File not found for logdump File cust.img loaded for cust File userdata.img loaded for userdata File not found for modem File not found for fsc File not found for ssd File not found for sbl1 File not found for sbl1bak File not found for rpm File not found for rpmbak File not found for tz File not found for tzbak File not found for devcfg File not found for devcfgbak File not found for dsp File not found for modemst1 File not found for modemst2 File not found for DDR File not found for fsg File not found for sec File splash.img loaded for splash File not found for aboot File not found for abootbak File boot.img loaded for boot File recovery.img loaded for recovery File not found for devinfo File system.img loaded for system File cache.img loaded for cache File persist.img loaded for persist File misc.img loaded for misc File not found for keystore File not found for config File not found for oem File not found for limits File not found for mota File not found for dip File not found for mdtp File not found for syscfg File not found for mcfg File not found for lksecapp File not found for lksecappbak File not found for cmnlib File not found for cmnlibbak File not found for cmnlib64 File not found for cmnlib64bak File not found for keymaster File not found for keymasterbak File not found for apdp File not found for msadp File not found for dpo File not found for logdump File cust.img loaded for cust File userdata.img loaded for userdata Writing [splash.img] -> [splash] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [system.img] -> [system] ...Done Writing [cache.img] -> [cache] ...Done Writing [persist.img] -> [persist] ...Done Writing [misc.img] -> [misc] ...Done Writing [cust.img] -> [cust] ...Done Writing [userdata.img] -> [userdata] ...Done Operation Finished. Module Ver. 2.1 |
05-20-2018, 11:20 | #12 (permalink) |
Member: 2836815 Status: Offline Thanks Meter: 1 | doesnt work,gets relocked all the time Operation : Disable Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 5X [msm8953] Software : QL1515-tiffany-build-20180406011341, V9.5.3.0.NDBCNFA [Fri Apr 6 01:13:10 CST 2018] Android Ver. : 7.1.2 Patch Level : 2018-03-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. Module Ver. 2.1 |
