09-14-2018, 12:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Caterpilar S40 frp failed Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM72) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 8F1359FD1554B6295A938DC2BCAA90ADE0D790FD1A7758B0A0 07AFE1F5FF0DC5 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8909_001.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. https://www.gsmarena.com/cat_s40-7456.php |
09-14-2018, 15:56 | #2 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | you need the correct loader https://www.clansoft.net/dl/index.ph...b=file&id=3553 |
The Following User Says Thank You to bruno santana For This Useful Post: |
09-14-2018, 16:08 | #3 (permalink) | |
Member: 1800628 Status: Offline Thanks Meter: 940 | Quote:
hey bro..i can't register there..can you upload here this file? | |
09-15-2018, 01:38 | #5 (permalink) |
Member: 1800628 Status: Offline Thanks Meter: 940 | Finally done..... Thank to Bell666 for your file(Factory loader)...... Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM72) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 8F1359FD1554B6295A938DC2BCAA90ADE0D790FD1A7758B0A0 07AFE1F5FF0DC5 Initializing Protocol...OK Sending Loader [Qualcomm_Factory_Loader_MSM8909_Cat_S40.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : BullittGroupLimited S40 [msm8909] Software : LTE_D0201121.0_S40_0.030.01, 2085 [Thu Oct 26 19:06:23 CST 2017] Android Ver. : 5.1 Patch Level : 2017-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 2.7.0 one more...thank big to Bell666 for your help. |
The Following 3 Users Say Thank You to Deni's For This Useful Post: |
