08-20-2018, 22:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Disable & Restore locks Disable &Restore locks for encrypted device Does it supports oreo |
08-21-2018, 04:22 | #4 (permalink) |
No Life Poster Join Date: Jul 2012 Location: kashmir, india
Member: 1781818 Status: Offline Sonork: 100.1652308:ashaq Thanks Meter: 130 | If you have any mobile but qualicom it have pattern pin finger lock etc you can disable all locks without data lose that is it |
08-21-2018, 05:20 | #6 (permalink) |
No Life Poster Join Date: Sep 2017 Location: INDONESIA
Member: 2755295 Status: Offline Thanks Meter: 198 | I never tried to disable lock on vivo y55s all says done but after all finished vivo entered to "repair" & hard reset (via recovery) mode system and fs via umt no change and always entered to the "sytem repair mode" i need to ask is what are we doing after disablelocks ???? |
08-21-2018, 07:33 | #7 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | If you had read update thread properly, you could already have the answer. It is supposed to work on all Generic Qualcomm Devices and Xiaomi too. On some vivo it works, on some not, because they have customized their version of Android. You can use it on any Android Version, it will disable Lock screen and you can enter phone and make backup of data you want. To restore phone to back to original state, just do Restore Locks. If you phone entered repair mode, or any other mode after Disable Locks, you always have option to Restore Locks to get phone back to previous state. Hope it clears everything. About success logs, there are many in our section, just use magic called SEARCH (just for note, ABRACADABRA does not work anymore.) Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
08-21-2018, 08:48 | #8 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | This is not working in V9 shDevice : Vivo V9 Operation : Restore Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_014.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1723 Software : OPM1.171019.011 release-keys, eng.compil.20180604.221527 [Mon Jun 4 22:15:27 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-05-01 USERDATA : Encrypted Restoring Android Locks...Done Operation Finished. owing done but not done |
08-21-2018, 08:49 | #9 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Device : Vivo V9 Operation : Disable Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_014.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1723 Software : OPM1.171019.011 release-keys, eng.compil.20180604.221527 [Mon Jun 4 22:15:27 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-05-01 USERDATA : Encrypted Disabling Android Locks...Done Operation Finished. |
08-21-2018, 08:58 | #10 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | During Disable locks not making any backup simply showing disabling locks done not making any backup same position while restoring this method not working |
08-21-2018, 09:28 | #11 (permalink) | |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | Quote:
and now just thread closed already answered by BOSS br owais a UMT Team | |
08-21-2018, 16:12 | #12 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
If backup is needed, software will surely make it, if software does not make it, that means its not needed. Br, UMT | |
