09-29-2019, 20:44 | #1 (permalink) |
Insane Poster Join Date: Dec 2015 Location: Sudan
Member: 2495537 Status: Offline Thanks Meter: 16 | DUB-LX1 can't flash anything after reviving solved via QCfire Some models after reviving via UMT or Qfil you can't flash anything on them and you are Stuck with firmware without customization (missing system files , file manager themes etc) The solution for that is to extract *Userdata.img *Version.img *Cust.img From the custmization file , the one you get with update.app , and then from UMT go to advance flasher, select the loader from the revive file (umt qfile revive file) , and click connect , use the test point to make the phone switch to Qualcomm 9008 mode , and then you will see all the partitions after successful connection , select userdata and point it to the location of userdata.img Select cust and point to the location of cust.img Select version and point to the location of version.img And click flash selected After it's done connect the battery and turn on the phone and everything should be in place . ## you can use UMT app converter to extract the files from the custmization file . ## and you can convert the whole update.app to xml to flash via EDL for better results . We used the update file 143 , the one you was supposed to flash via Sdcard . |
The Following User Says Thank You to awab228 For This Useful Post: |
