01-13-2018, 06:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | e5573s-606 unlock file flashing error-help Port : COM28 : FC - PC UI Interface (COM28) Baud Rate : 921600 Device : Huawei E5573 Operation : Read Info Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573s-606 Revision : 21.315.01.01.284 IMEI : 866079027488862 Build : Mar 24 2016, 16:03:05 Software : 21.315.01.01.284 Dashbaord : WEBUI_17.100.14.01.284_MRE5 Hardware : CL1E5573SM Ver.A Flash Code : 66203283 Lock Status : Locked (10 Attempts Left) Port Closed. Operation Finished. Elapsed Time: 00:04 [Module Ver. 4.6] Log Saved to Logs\180113_092029.log unlock file flashing error as below Port : COM28 : FC - PC UI Interface (COM28) Baud Rate : 921600 Device : Huawei E5573 Operation : Write Firmware Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573s-606 Revision : 21.315.01.01.284 IMEI : 866079027488862 Build : Mar 24 2016, 16:03:05 Software : 21.315.01.01.284 Dashbaord : WEBUI_17.100.14.01.284_MRE5 Hardware : CL1E5573SM Ver.A Flash Code : 66203283 Firmware : [BV7R11EU] [21.110.99.03.00] Partitions : 10 Preparing Device... OK Setting Download Mode... OK Waiting for Device... OK Port Found : COM26 : FC - PC UI Interface (COM26) Opening Port... OK Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZM Device : HUAWEI BV7R11EU Starting Flashing Process... Writing Partition... [0x00110000]... Resp Err! Write Err Tick Emergency Mode and Flash again. Port Closed. Operation Failed. Elapsed Time: 00:35 [Module Ver. 4.6] Log Saved to Logs\180113_093152.log this firmware not support for unlock? |
01-13-2018, 06:38 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
THEN INSERT BATTERY IN MODEM AND SHORT THE MODEM TP POINTS E5573S TP POINTS ADDED IN UMT SUPOURT THEN FOLLOW THIS UNLOCK GUIDE http://forum.gsmhosting.com/vbb/f970...nside-2186410/ BR-BALWINDER27 UMT-TEAM | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
