10-05-2019, 10:25 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Did you tried to update driver as suggested in log? Make sure this phone is not write protected as most vivo phones are now being protected for write. About other tool, you can send me log in PM, as we do not allow posting other tool log here. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
10-05-2019, 10:49 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
thanks for respond | |
10-05-2019, 14:03 | #8 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Can you please post will log instead of just simple screenshot which shows nothing but only a few files? Post full log with both name full name of rawprogam and patch you used. I will check and upload firmware for you if needed. Please make sure your device is 1730CF with 6GB RAM. Br, UMT Last edited by U.M.T; 10-05-2019 at 14:08. |
10-05-2019, 14:39 | #9 (permalink) | |
Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 04007300 OPK_DATA : A103747D6F285B7FDDA476A5E985F67EB8D73574FB572BC345 35197B5417B2E1 Initializing Protocol...OK Sending Loader [prog_emmc_ufs_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Writing [xbl.elf] -> [xbl] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [PD1730CF_EX_fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [system_12.img] -> [system] ...Done Writing [vendor_1.img] -> [vendor] ...Done Writing [vendor_2.img] -> [vendor] ...Done Writing [vendor_3.img] -> [vendor] ...Done Writing [vendor_4.img] -> [vendor] ...Done Writing [vendor_5.img] -> [vendor] ...Done Writing [vendor_6.img] -> [vendor] ...Done Writing [vendor_7.img] -> [vendor] ...Done Writing [vendor_8.img] -> [vendor] ...Done Writing [boot.img] -> [boot] ...Done Writing [keymaster64.mbn] -> [keymaster] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [abl.elf] -> [abl] ...Done Writing [sec.dat] -> [sec] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [recovery.img] -> [survival] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [cache_4.img] -> [cache] ...Done Writing [recovery.img] -> [recovery] ...Done [PROTECTIVE_FLASH] Skipping [modemst.mbn] -> [modemst1] Writing [persist_1.img] -> [persist] ...Done Writing [persist_2.img] -> [persist] ...Done Writing [persist_3.img] -> [persist] ...Done Writing [persist_4.img] -> [persist] ...Done Writing [persist_5.img] -> [persist] ...Done [PROTECTIVE_FLASH] Skipping [modemst.mbn] -> [modemst2] Writing [devcfg.mbn] -> [devcfg] ...Done Writing [storsec.mbn] -> [storsec] ...Done Writing [oem_1.img] -> [oem] ...Done Writing [oem_2.img] -> [oem] ...Done Writing [oem_3.img] -> [oem] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [userdata_13.img] -> [userdata] ...Done Writing [userdata_14.img] -> [userdata] ...Done Writing [athena.img] -> [athena] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.9 i used this firmware 6gb ram Vivo_V9_PD1730CF_EX_A_6.7.6_LA.UM.7.2.r1-00600-sdm660_QFIL | |
10-05-2019, 14:42 | #10 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Can you please contact me on Skype? Do you have very first log with QcFire? When phone had faulty emmc? Br, UMT |
10-05-2019, 14:57 | #11 (permalink) | |
first log Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 04007300 OPK_DATA : A103747D6F285B7FDDA476A5E985F67EB8D73574FB572BC345 35197B5417B2E1 Initializing Protocol...OK Sending Loader [prog_emmc_ufs_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [xbl.elf] -> [xbl] ...Failed Operation Finished. QcFire Ver. 4.9 | |
10-07-2019, 14:12 | #14 (permalink) |
Insane Poster Join Date: Oct 2008 Location: indonesia
Member: 887723 Status: Offline Sonork: dr ckr Thanks Meter: 4 | i think, u have same problem as mine , by using 6.7.6 firmware it can flashing , but did not take any effect with the phone , it use skhynix H9HP52AECMMD emmc with 254 socket , maybe fully protected or broken , u can try flash with half way and you disconnected yours phone , yours phone still ON and still same problem from begining. i still waiting isp pinout for this model . |
