07-11-2019, 13:55 | #18 (permalink) |
Junior Member Join Date: Jan 2018 Location: banglore
Member: 2800212 Status: Offline Sonork: 1682265 Thanks Meter: 4 | How to Solve This Issue getting an error while running to do a job, and there is no Winpac in uninstall program So I completely uninstall And restart the PC & all setup and re-install, But the same thing happening How to rectify This please Advice Who Solved This Issue!! |
09-18-2019, 09:00 | #20 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Just check logs folder for err.log file. It contains information about forbidden application. Br, UMT |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
03-19-2020, 12:53 | #25 (permalink) | |||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
It's all Br allumts | |||
03-19-2020, 13:35 | #26 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | If you check in another computer and it works, that means your computer has a window problem,We have solved many people for example, sir Once you have checked the pc healed or window B,R Unlockinfo |
The Following 2 Users Say Thank You to Unlockinfo For This Useful Post: |
03-19-2020, 16:18 | #27 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
After that, make sure you have full control to sytem32 folder, and instead of delete, simply rename file and reboot PC. Br, UMT | |
03-19-2020, 17:18 | #28 (permalink) | ||
i this file above haven't find. I've find only this: Quote:
I can only Rename if not damage other box/dongle installed in my pc. BR allumts | ||
03-19-2020, 18:37 | #29 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | OK all Solved!!! 1) tick show hidden device in device manager 2) and then check under System Devices 3) or under Universal serial bus controller 4) and delete and reboot 5) Install Qfire5.4 all work fine. Very thanks to UMT Team for help and solved in 5 mins Br allumts |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
03-31-2020, 13:21 | #30 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: MALDIVES
Member: 1324837 Status: Offline Sonork: jisankhan Thanks Meter: 58 | Forbidden Application [03] Detected! Error UMT Dongle solve for me. 1)Winpcap installed on u r pc (if alredy nt insteld) 2)uninstel Winpcap from control panel 3)once restart pc & enjoy hope this will help to solve this issue |
