Forbidden Application [AA] Caused USB 3.0 PCI VIA Good day, I have a problem with the tool (NCK Pro) that I acquired recently, I used it for a day on my usual PC (desktop PC) without any problem, the following day I got the error "Forbidden Application [AA] Detected !! Please Uninstall it and Restart PC! " I was looking at several forums and the applications I read that caused the error I did not have them installed, yet I deleted some that gave me suspicion but I continued with the error, today I found that the possible cause of this error was an .sys file In system32, I renamed it and restarted the PC, it did not boot and I got a blue screen, I could leave the file in question as it was, but better choose to format the PC and boot from zeros to avoid inconvenience, install system (Windows 7 Ultimate to 64 bits), clean system and installed the nck and umt modules, without problem, then I started to install drivers and verifying that everything was fine, until it was the turn of a 3.0 pci usb card that I have, when installing the drivers ( VIA plate) I started again the error mentioned above, are the drivers updated and official, is there any solution? |
Helpme please!!, any idea? |
Send me err.log from logs folder. Br, UMT |
The first image is the error, formatted equipment for the third time, in the first times I execute the error and it does not generate logs, after the fourth or fifth time I insist on opening it if it opens normally, and I attach the image 2 with the logs that generated |
It does not let me attach the photos, I leave the log it generates, it is almost clean because it is a new installation: Port : ADB Interface Baud Rate : Not Applicable Device : AllWinner Operation : Read Info Searching for Device... Not Found! Operation Failed. Elapsed Time: 00:02 [Module Ver. 5.4] |
Precisely the problem is with a PCI 3.0 chip VIA card |
Yes, problem solved, process usb3monitor.exe, rute "C:\program files\via xhci uasp utility" Thanks Man |
