09-25-2019, 02:45 | #1 (permalink) |
Junior Member Join Date: Oct 2007 Location: Colombia
Member: 603089 Status: Offline Thanks Meter: 0 | Forbidden Application [AA] Caused USB 3.0 PCI VIA |
09-27-2019, 22:47 | #5 (permalink) |
Member: 603089 Status: Offline Thanks Meter: 0 | The first image is the error, formatted equipment for the third time, in the first times I execute the error and it does not generate logs, after the fourth or fifth time I insist on opening it if it opens normally, and I attach the image 2 with the logs that generated |
09-27-2019, 23:02 | #6 (permalink) |
Member: 603089 Status: Offline Thanks Meter: 0 | It does not let me attach the photos, I leave the log it generates, it is almost clean because it is a new installation: Port : ADB Interface Baud Rate : Not Applicable Device : AllWinner Operation : Read Info Searching for Device... Not Found! Operation Failed. Elapsed Time: 00:02 [Module Ver. 5.4] |
10-10-2019, 16:02 | #9 (permalink) | |
Member: 603089 Status: Offline Thanks Meter: 0 | Quote:
Yes, problem solved, process usb3monitor.exe, rute "C:\program files\via xhci uasp utility" Thanks Man | |
