02-28-2017, 17:49 | #1 (permalink) |
Insane Poster Join Date: Aug 2015
Member: 2441148 Status: Offline Thanks Meter: 3 | G610F (j7 prime) FRP, pls help UMT Team. Device: SM-G610F_NEW Operation: Reset FRP Searching for Device... Found Model: SM-G610F Baseband: Bootloader: G610FDDU1AQA4 PDA: G610FDDU1APK4 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:07 [Ultimate Samsung Flasher v0.9] |
03-01-2017, 03:47 | #2 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Quote:
Try FRP new method frnd BR Sandeep kumar | |
03-01-2017, 04:07 | #3 (permalink) | |
Freak Poster Join Date: Dec 2005 Age: 47
Member: 205157 Status: Offline Sonork: 100.1574537 Thanks Meter: 82 | Quote:
03-02-2017, 08:12 | #7 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | UMT calling method so easy Quote:
[IMG]image hosting 10mb limit[/IMG] | |
08-21-2017, 10:07 | #9 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1478562 Status: Offline Thanks Meter: 54 | Finaly i got success with help of this video.... thanks to helps.... new security 2017 samsung g610f j7 prime frp lock solution 100% easy video... https://*********/-69SZ2UFcsI success video |
11-22-2017, 08:14 | #10 (permalink) |
Insane Poster Join Date: Jun 2012 Location: vasai, mumbai,india
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | SAMSUNG J7 PRIME (G610F )FRP SUCCESS WITH U.M.T. BUT VERRY LONG PROCCES 1st =COMPLATE FLASH YOUR MOBILE WITH THIS Bootloader: G610FDDU1AQC2 PDA: G610FDDU1API4 VERSON. 2nd =GO TO U.M.T. SAMSUNG UFD FRP RESET AND APPLY PATCH WITH THIS V.G610F_1AQC2 3rd =RESTAR YOUR MOBILE AND CLICK ON FRP RESET SUCCESE FRP UNLOCK BUT APP AND SHOW, NOW FLASH BOOT FILE FROM CUSTOM FLASHER 101% SUCCESE PLZ PRESS THANKS BUTTON |
The Following User Says Thank You to rrajsa For This Useful Post: |
11-22-2017, 08:16 | #11 (permalink) |
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | Device: SM-G610F_1AQC2 Operation: Apply FRP Patch Port: COM18 : SAMSUNG Mobile USB Modem #7 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-G610F IMEI: *********** Software: G610FDDU1API4/G610FODD1API6/G610FDDU1API7/G610FDDU1API4 Init Download Mode... OK Port: COM3 : SAMSUNG Mobile USB Modem Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Applying Patch Data... . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 01:08 [Ultimate Samsung Flasher v1.3] Device: SM-G610F_1AQC2 Operation: Reset FRP Searching for Device... Found Model: SM-G610F Baseband: G610FDDU1API7 Bootloader: G610FDDU1AQC2 PDA: G610FDDU1API4 Android Version: 6.0.1 Resetting FRP Lock... Done Operation: Flash Firmware Port: COM3 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Sending Partition [BOOT]... Done Closing Session... Done Operation Finished. Elapsed Time: 00:18 [Ultimate Samsung Flasher v1.3] |
11-22-2017, 08:18 | #12 (permalink) |
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | Just see my post your problem solv |
11-23-2017, 15:07 | #14 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | Sm-g610f perfect solution 10000% by umt 1.first flash the phone with any available firmware for ex ddu1aqb1 2.wait for phone to turn on completely. 3.use sm-g610f.ufd file to write in download mode 4.after ufd write phone appears to hang.u get message system not responding.at this stage if anyone try to reset frp it fails. 5.hold three buttons together (vol- home power) for few min 6.again connect phone in download mode 7.select boot.img and sboot.bin from og firmware.and write it 8.this time phone turn on and works normal.adb is on by default 9. Now reset by umt.its done note: If anyone has doubt that adb will be off by og boot.img then my suggestion is please try it for one time as i said press thanks button if helpful |
