03-26-2020, 15:20 | #17 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
1) tick show hidden device in device manager 2) and then check under System Devices 3) or under Universal serial bus controller 4) delete "Eltima serial bus port" and reboot 5) Install Qfire5.5 all work fine. Br allumts | |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
03-30-2020, 14:06 | #18 (permalink) |
Freak Poster Join Date: Feb 2004 Location: izmir Age: 48
Member: 53215 Status: Offline Thanks Meter: 17 | umt qc fire 5.4 ve 5.5 setup ta program da forbidden-application-11-detected- hatası veriyor. umt qc fire 4.9 ve 5.0 setup ok pro ok. program sorunsuz çalışıyor. flexihup wincap not setup kurulu değil. eltima serial bus none yok. 5.4 ve 5.5 çalışmıyor. |
03-30-2020, 14:45 | #19 (permalink) | |
So or post Log from LOGS from UMT QFIRE or Read and Apply my 100% tested Procedure here: http://forum.gsmhosting.com/vbb/14056596-post18.html Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
05-16-2020, 14:57 | #21 (permalink) | |
Crazy Poster Join Date: Jan 2011
Member: 1490445 Status: Offline Thanks Meter: 3 | Quote:
Forbidden Application [10] Detected! Please restart software Help please Uninstall flexihub, WinPcap, look through TeamViewer, skype dganhot-600 waiting for you, thanks | |
05-16-2020, 15:39 | #22 (permalink) | |
05-17-2020, 09:40 | #27 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | See? there are Trace of USB Sharing program, in this case "FLEXIHUB" So read and Apply carefully my tested and working procedure in post #20 If want solve in 2 minuts, otherwise continue with you useless attempt Br allumts |
05-17-2020, 13:26 | #30 (permalink) |
Member: 1490445 Status: Offline Thanks Meter: 3 | I deleted the virtual serial bus emulator 9, it still doesnt work, I will try to upload a photo of the device manager, https://dropmefiles.com/XHeLU |
