Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 03-26-2020, 14:19   #16 (permalink)
Member: 2118052
Thanks Meter: 568
Dear sir,
First install fexihub
Open 1 time n exit.
Restart pc in safe mode then uninstall flexi..
Now normal reboot ... Enjoy...
Old 03-26-2020, 15:20   #17 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Originally Posted by edazor View Post
how do card info error.
card update latest info ?
card update please.
qc fire 5,4 and 5.5 frp and root ...... not edl mode pro forbidden-application-11-detected error.
frp modül quadrom ok pro. ?
Solution 100%:
1) tick show hidden device in device manager
2) and then check under System Devices
3) or under Universal serial bus controller
4) delete "Eltima serial bus port" and reboot
5) Install Qfire5.5 all work fine.
allumts
The Following 2 Users Say Thank You to allumts For This Useful Post:
Old 03-30-2020, 14:06   #18 (permalink)
Member: 53215
Thanks Meter: 17
umt qc fire 5.4 ve 5.5 setup ta program da forbidden-application-11-detected- hatası veriyor.
umt qc fire 4.9 ve 5.0 setup ok pro ok. program sorunsuz çalışıyor.
flexihup wincap not setup kurulu değil. eltima serial bus none yok. 5.4 ve 5.5 çalışmıyor.
Old 03-30-2020, 14:45   #19 (permalink)
allumts's Avatar
Member: 1564612
100% you have trace of FlexiHub.
So or post Log from LOGS from UMT QFIRE
or
Read and Apply my 100% tested Procedure here:
http://forum.gsmhosting.com/vbb/14056596-post18.html
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 03-30-2020, 16:55   #20 (permalink)
Member: 53215
Thanks Meter: 17
ok allumts
eltima serial port delete ok pro.
Old 05-16-2020, 14:57   #21 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
Originally Posted by Unlockinfo View Post
uninstall Setup. Delete folder C:\UMTool
install again setup and restart pc, check
or
Follow UMT Manager Post
http://forum.gsmhosting.com/vbb/f970.../#post12284250
Forbidden Application [10] Detected!
Please restart software
Help please
Uninstall flexihub, WinPcap,
look through TeamViewer, skype dganhot-600
waiting for you, thanks
Old 05-16-2020, 15:39   #22 (permalink)
allumts's Avatar
Member: 1564612
Help please
Here Tested 100% procedure easy:
allumts
Old 05-16-2020, 15:43   #23 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
allumts
tried everything did not help, if anyone can help, I will give access to TeamViewer
Old 05-16-2020, 15:44   #24 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
please check remotely
Old 05-16-2020, 18:35   #25 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Simply open Logs\err.log file and post what is there.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 05-16-2020, 20:35   #26 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
Br,
UMT
vhclient:VirtualHere Client USB Sharing
Old 05-17-2020, 09:40   #27 (permalink)
allumts's Avatar
Member: 1564612
See? there are Trace of USB Sharing program, in this case "FLEXIHUB"
So read and Apply carefully my tested and working procedure in post #20
If want solve in 2 minuts, otherwise continue with you useless attempt
allumts
Old 05-17-2020, 11:44   #28 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
which one to remove from them, I do not see
Old 05-17-2020, 11:56   #29 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
I can’t upload the photo now, I’ll try later
Old 05-17-2020, 13:26   #30 (permalink)
Crazy Poster
Member: 1490445
Thanks Meter: 3
I deleted the virtual serial bus emulator 9, it still doesn’t work, I will try to upload a photo of the device manager, https://dropmefiles.com/XHeLU
Page generated in 0.23416 seconds with 8 queries
