12-18-2019, 05:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | uninstall Setup. Delete folder C:\UMTool install again setup and restart pc, check or Follow UMT Manager Post http://forum.gsmhosting.com/vbb/f970.../#post12284250 |
The Following User Says Thank You to Unlockinfo For This Useful Post: |
12-18-2019, 09:10 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You have Eltima software/driver installed. Remove them. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
03-17-2020, 12:11 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi bro, I haven't any FlexiUhub istalled, all other Setup working very fine, like MTK, UMT Gsm itc... only this last version 5.4 UMT QFire today is getting this error. If i had Eltima Sw installed No one of other Exe was working, only this Qfire get this: Quote:
allumts | |
03-17-2020, 16:38 | #6 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527517 Status: Offline Sonork: 100.1607096 Thanks Meter: 9 | Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM32) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SDM665]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.4 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM32) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjRDMzg3NTVBNkY1MDYyNE E0ODQ0MzI1NTM3NjEzNTcyNUE1MDczNjU3MDczNTYzOTRDNzE3 Nz== Requesting UMT Server for Auth Data...No Credits Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.4 |
03-17-2020, 19:34 | #8 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok now remember that 15 days ago i've used Flexi for reset FRP by Server. But i've unistalled this Flexi same day, and are 15 days i power on my pc normally w/o this Flexi installed. I not understand why get this error the Logs Folder: Quote:
Br allumts | |
03-17-2020, 21:48 | #9 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 234 | brother, Quote:
03-17-2020, 22:42 | #10 (permalink) | |
No Life Poster Join Date: Mar 2013
Member: 1900730 Status: Offline Thanks Meter: 188 | Quote:
03-18-2020, 13:22 | #11 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Is Strange that also CGPro key work fine, and this detect immediate any trace of Flexi. Who can help me to seach Directory where's can be some drivers this Lol program? | |
03-26-2020, 11:32 | #14 (permalink) |
Freak Poster Join Date: Feb 2004 Location: izmir Age: 48
Member: 53215 Status: Offline Thanks Meter: 17 | how do card info error. card update latest info ? card update please. qc fire 5,4 and 5.5 frp and root ...... not edl mode pro forbidden-application-11-detected error. frp modül quadrom ok pro. ? Last edited by edazor; 03-26-2020 at 11:38. |
03-26-2020, 12:31 | #15 (permalink) | |
Also loock belowe: http://forum.gsmhosting.com/vbb/f970.../#post12284250 And loock my Solved issue here: http://forum.gsmhosting.com/vbb/14051704-post29.html Br Allumts | |
