12-04-2019, 20:20 | #1 (permalink) |
Crazy Poster Join Date: Feb 2009
Member: 975900 Status: Offline Thanks Meter: 10 | How can I remove mi account on note 6 pro? i tried using qc fire 5.0 , "reset mi acc" but the sistem can´t detect the phone. I,ve entered in edl mode using the specific testpoing(ihave installed drivers of course...it is succesfully installed), but It can´t detect the phone. What can i do? regards!! |
12-05-2019, 12:07 | #5 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, use module qcfire 4.8, uncheck using umt server and to unlock the bootloader of the redmi note 6 pro, in the unlock bootloader box of the special xiaomi tab put redmi note 7, as you are supposed to know how to use the same loader and the same processor, things to keep in mind, if the xiaomi is in android version 8.1 it will give you image perfectly, if on the contrary the xiaomi is in android 9 it will not give you image, the screen will be in black, but it will unlock the bootloader without problem and only you have to return to miui 10 with the firmware of the redmi note 6 pro and then do the operation of removing xiaomi account, do not connect wifi, or data, if it will not be blocked, until you do not finish doing all the operations including the relock. |
The Following 3 Users Say Thank You to Franky_36 For This Useful Post: |
12-05-2019, 19:39 | #6 (permalink) | |
Member: 975900 Status: Offline Thanks Meter: 10 | Quote:
Hi again! good, now qcfire can detect my phone but always the same mesage when I try unlock boot(note 7 selected on EDL Mode) : Operation : Xiaomi Boot Patch Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM125) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. AND THIS IS ON FAST BOOT: Operation : Bootloader Unlock (Fastboot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : GetVar Variable Not found Product : tulip Bootloader : Locked Unlocking Bootloader...Failed QcFire Ver. 4.9.1 what can I do now? | |
12-05-2019, 19:52 | #7 (permalink) | |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
12-07-2019, 10:17 | #9 (permalink) | |
12-07-2019, 10:40 | #10 (permalink) | |
https://www.youtube.com/watch?v=IxBvA9fFFw0&t=133s Last edited by Franky_36; 12-07-2019 at 10:47. | |
12-07-2019, 11:04 | #11 (permalink) | |
Thank you, I was wrong with you then. I have had the box for less than a week and it is very frustrating at first. I have a problem with support area because it only lets me download version 5.0 and 4.9 ... I can't download 4.8 (maybe this version does not fail with this model). I will take a look at the video, I will surely understand (I´m fron Spain ) Thanks again!! | |
12-07-2019, 12:07 | #12 (permalink) | |
Umt qcfire 4.8 link: https://drive.google.com/file/d/1EGO...ew?usp=sharing Umt qcfire 4.7 link: https://drive.google.com/file/d/1aIP...ew?usp=sharing | |
12-07-2019, 12:43 | #13 (permalink) |
Member: 975900 Status: Offline Thanks Meter: 10 | thanks!! I´ve watched the video,and I´m doing exactly what it explains...but always the same problem when I try to unlock boot in EDL mode(on fast boot it can´t unlock it): Operation : Xiaomi Boot Patch Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM125) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. -I´ve tried, with 4.7,4.8,4.9 and 5.0 qc fire -tick and untick "USE UMT AUTH SERVER" -connected and disconected battery after testpoing(just in case) the model is m1806E7TG ,redmi note 6 pro(I hace checked again) miui 10 It is strange, can it be about the firmware version or android problem?? |
12-07-2019, 13:21 | #14 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 937 | Quote:
try with restart pc and try connect again.. | |
12-10-2019, 06:54 | #15 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,081 | Make sure not other program is interfering with it. Seems some other program capture or opened port before QcFire. Click Patch button and connect phone when asked by software. |
