04-26-2017, 05:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Punjab Age: 29
Member: 2559593 Status: Offline Thanks Meter: 75 | How to unlock Idea 4g Modem Huwaei e5573 ??? But On Support Area only Airtel E5573 Firmware Available Plz Help How Can i UNLCOK this Idea 4g modem log Port : COM108 : FC - PC UI Interface (COM108) Baud Rate : 921600 Device : Huawei E5573 Operation : Unlock Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573s-606 Revision : 21.200.15.00.356 IMEI : 866079027155586 Build : Nov 04 2015, 09:56:11 Software : 21.200.15.00.356 Dashbaord : WEBUI_17.100.12.01.356_MRE5 Hardware : CL1E5573SM Ver.A Flash Code : 56533718 Lock Status : Unlocked (10 Attempts Left) Resetting Network Lock... Failed Flash Unlock Firmware from Support First! Port Closed. Operation Failed. Elapsed Time: 00:04 [Module Ver. 3.8] Log Saved to Logs\170426_100713.log |
04-26-2017, 11:51 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
Unscrew a modem short a tp testpoint And repair e5573s boot repair Then tick emergency option Then write Airtel only firmware then unlock a modem Then write Airtel final firmware | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
04-27-2017, 07:55 | #3 (permalink) | |
battery must be insrerted in a modem and short testpoint then repair e5573s repair pack then slect huawi pc ui com port and tick option emergency then write firmwrae airtel unlock only after firmwrae write unlock a modem then untick emergency option write 2nd firmwrae airtel final done | |
The Following 3 Users Say Thank You to balwinder27 For This Useful Post: |
