05-30-2017, 04:55 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: the boss of samsung
Member: 2558211 Status: Offline Thanks Meter: 90 | HUAWEI MODEM flash error Baud Rate : 921600 Device : Huawei E5573 Operation : Write Firmware (Emergency) Opening Port... OK Firmware : [BV7R11EU] [21.110.99.03.00] Partitions : 10 Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZ Device : HUAWEI BV7R11EU Starting Flashing Process... Writing Partition... [0x00110000]... OK Writing Partition... [0x00200000]... OK Writing Partition... [0x00010000]... OK Writing Partition... [0x00090000]... OK Writing Partition... [0x00220000]... OK Writing Partition... [0x00230000]... OK Writing Partition... [0x00240000]... OK Writing Partition... [0x00250000]... OK Writing Partition... [0x00590000]... OK Writing Partition... [0x005A0000]... OK Waiting for Modem... . . . OK Port : COM235 : Mobile Connect - 3G PC UI Interface (COM235) Restoring Data... Sync Error! Port Closed. Operation Finished. Elapsed Time: 01:39 [Module Ver. 3.4] Log Saved to Logs\170529_235740.log |
05-30-2017, 06:02 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
Dear user. As I seen you not inserted battery In e5573 router .battery required in router when you flashing a firmware and unlock .insert battery in router then flash a firmware .you not face this error again If you face any error again contact me on my Skype I resolve issue BR-UMT TEAM HUAWEI | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
05-30-2017, 06:27 | #3 (permalink) | |
Member: 2558211 Status: Offline Thanks Meter: 90 | Quote:
05-30-2017, 06:27 | #4 (permalink) | |
Member: 2558211 Status: Offline Thanks Meter: 90 | For info Quote:
05-30-2017, 06:30 | #5 (permalink) |
Member: 2558211 Status: Offline Thanks Meter: 90 | Port : COM215 : HUAWEI Mobile Connect - 3G PC UI Interface (COM215) Baud Rate : 921600 Device : Huawei E5573 Operation : Write Firmware (Emergency) Opening Port... OK Firmware : [BV7R11EU] [21.110.99.03.00] Partitions : 10 Checking Device... OK Validating Boot Mode... OK Bootloader : 7200B--SKCBADZ Device : HUAWEI BV7R11EU Starting Flashing Process... Writing Partition... [0x00110000]... OK Writing Partition... [0x00200000]... OK Writing Partition... [0x00010000]... OK Writing Partition... [0x00090000]... OK Writing Partition... [0x00220000]... OK Writing Partition... [0x00230000]... OK Writing Partition... [0x00240000]... OK Writing Partition... [0x00250000]... OK Writing Partition... [0x00590000]... OK Writing Partition... [0x005A0000]... OK Waiting for Modem... . . . OK Port : COM215 : HUAWEI Mobile Connect - 3G PC UI Interface (COM215) Restoring Data... Sync Error! Port Closed. Operation Finished. Elapsed Time: 01:37 [Module Ver. 3.4] Log Saved to Logs\170530_013328.log |
05-30-2017, 08:38 | #6 (permalink) | |
Dear 1st mention your model number of e5573s series Every country e5573s modems have different security different firmware use Please tell full model number of e5573s Like e5573s-606 e5573s-156 | |
