08-22-2018, 07:15 | #18 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | if you are developer then you can make your own root kernel don't spam section, if you able to open diag port you can write imei through diag port else use edl mode first reset efs, read qcn, edit qcn and write qcn |
10-14-2018, 22:23 | #21 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | Quote:
11-02-2018, 02:24 | #23 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529586 Status: Offline Thanks Meter: 40 | Enable diag mode on infinix x608, x622 hot s3x, x573 without root, etc see guide here https://goo.gl/w86w1V |
11-02-2018, 02:30 | #24 (permalink) |
04-29-2019, 10:21 | #28 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | X608 correct QCN Neeeded Starting.. Opening Port.. COM369 (Qualcomm HS-USB Android DIAG 9020 ) Compile : Oct 31 2018 21:40:22 Release : Apr 09 2018 01:00:00 Hw Ver : 8937.gen Build : N/A imei : N/A imei 2 : 000000000000000 Checking Qcn File... Invalid File! >>Process Failed... |
04-29-2019, 10:21 | #29 (permalink) |
