Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 03-13-2016, 04:40   #1 (permalink)
Member: 1096375
Thanks Meter: 44
j200g frp not done
Port : COM63 : SAMSUNG Mobile USB Modem #9
Baud Rate : 921600
Device : Samsung
Operation : FRP Lock Reset
Opening Port... OK
Checking for Device in Download Mode... Found
Reading Data from Phone... Done
Chipset : LSI3475 [High Speed]
Checking for FRP Data... Found
FRP Bit : ECEE
Resetting FRP Lock Data... Resp. Err: 0x04
Port Closed.
Operation Failed!
Elapsed Time: 00:11
Module Ver. [1.8]
Log Saved to Logs\160313_090428.log
Screenshot copied on clipboard.
please help
Old 03-13-2016, 05:14   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Baud Rate : 921600
Device : Samsung
Opening Port... OK
FRP Bit : ECEE
Port Closed.
Operation Failed!
Elapsed Time: 00:11
Module Ver. [1.8]
please help
More then 10 success log found in last several days , follow them or contact any supporter .
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-13-2016, 05:30   #3 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Baud Rate : 921600
Device : Samsung
Opening Port... OK
FRP Bit : ECEE
Port Closed.
Operation Failed!
Elapsed Time: 00:11
Module Ver. [1.8]
please help
Strange you do not read update news, or i think you just visited forum to post your complaint only.
For your kind info, we have latest ver 1.9. Check sticky thread.
Br,
Ultimate Multi Tool
Old 03-13-2016, 07:20   #4 (permalink)
Member: 1096375
Thanks Meter: 44
Dear Sir we download 1.9 update but still same problem here
Device: SM-J200G
Operation: Reset FRP / RL / EE
Port: COM125 : SAMSUNG Mobile USB Modem #17
Checking for Device... Found [Normal Mode]
Reading Phone Information... OK
Model: SM-J200G
IMEI: 353508071345388
Software: J200GDDU1APB1/J200GODD1APB1/J200GDDU1APB1/J200GDDU1APB1
Init Download Mode... OK
Port: COM63 : SAMSUNG Mobile USB Modem #9
Chipset: LSI3475 [HiSpeed]
Resetting FRP Lock Data... Rejected!
FFFFFFFFFFFFFFFF
Use FRP Reset Package and then Reset FRP.
Elapsed Time: 00:49
Old 03-13-2016, 07:24   #5 (permalink)
Member: 1096375
Thanks Meter: 44
kindly shere video process of this trick
Old 03-13-2016, 07:25   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Device: SM-J200G
Model: SM-J200G
FFFFFFFFFFFFFFFF
Elapsed Time: 00:49
I think you have not read the log fully
Br - srinibas
Old 03-13-2016, 07:27   #7 (permalink)
Member: 1096375
Thanks Meter: 44
also face error cannot create file c;\temp\test_sboot.bin the system can not find the specifiesd path
Old 03-13-2016, 07:32   #8 (permalink)
Member: 1096375
Thanks Meter: 44
also try with same *** per log
Old 03-13-2016, 08:09   #9 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
I cant assist you ( now ) remotely , Advised you to do a little search & see the screen shot & log , It will help you
Br - srinibas
Old 03-13-2016, 08:18   #10 (permalink)
Member: 1096375
Thanks Meter: 44
not good support from umt team
waste for money to buy this tool this time
hope in future good support and help
Old 03-13-2016, 08:23   #11 (permalink)
Member: 1228517
Thanks Meter: 39
http://forum.gsmhosting.com/vbb/11690022-post339.html
Old 03-13-2016, 08:37   #12 (permalink)
Member: 1096375
Thanks Meter: 44
Originally Posted by seakrokram View Post
try to under stand
Old 03-13-2016, 08:39   #13 (permalink)
U.M.T's Avatar
Member: 2465108
Red face
Aha, you are really a nice user, who believe he is so smart and intelligent, and all others are not supporting, or are fools.
What about my private message which i sent you to solve can't create error? You didn't received or cant read?
Even you cant read logs properly:
And cant even search:
http://forum.gsmhosting.com/vbb/11680484-post2.html
http://forum.gsmhosting.com/vbb/f970...d-1st-2061683/
http://forum.gsmhosting.com/vbb/f970...a-umt-2060261/
http://forum.gsmhosting.com/vbb/f970...-done-2060058/
So, if you still think that you wasted your money buying our tool, then please let me know here, so i will make sure that you can not use our tool anymore.
No regards,
Old 03-18-2016, 01:33   #14 (permalink)
Member: 1096375
Thanks Meter: 44
No regards,
Dear Sir we buy the tool Mr hassan from Delhi j200g not unlocked but j700 frp reset by usages package and frp reset
Also help your private message for me
Old 03-18-2016, 01:34   #15 (permalink)
Member: 1096375
Thanks Meter: 44
AMD also z3x. Chimera tool bst octoupus reject the same but umt frp reset fone
Page generated in 0.28936 seconds with 9 queries
