12-15-2018, 07:55 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: NIGERIA
Member: 2312129 Status: Offline Thanks Meter: 139 | Lenovo K520 failed yesterday Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM124) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 9A3BE293E298555C1AA96321648FB1CD5F66EE326534457DD6 7958BDB00D5656 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8953_001]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.4 |
12-15-2018, 08:51 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | We will try to update loader for it in next update. If you have Factory Firmware, you can try using loader from it if exists. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
04-14-2019, 13:57 | #4 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 894846 Status: Offline Sonork: ajmal Thanks Meter: 111 | Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 9A3BE293E298555C1AA96321648FB1CD5F66EE326534457DD6 7958BDB00D5656 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_026]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Lenovo Lenovo K520 Software : OPR1.170623.032 dev-keys, 3.7.208_180630 [2018年 07月 01日 星期日 00:31:53 CST] Android Ver. : 8.0.0 Patch Level : 2018-06-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. |
The Following User Says Thank You to ajmal_khan713 For This Useful Post: |
