09-05-2019, 19:52 | #1 (permalink) |
Insane Poster Join Date: Sep 2012 Location: gaziantep turkiye
Member: 1806384 Status: Offline Thanks Meter: 12 | Mİ 8 lİte reset efs error Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAD0BAABo7CdOT1NDaK_hsMDRk33nlGcSDA Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 sideload efs reset okk but it doesn't reset plz help me |
09-05-2019, 21:14 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Two things to remember for EFS Reset in Sideload: 1. Device must have stock recovery. 2. It may not work on some firmware/device. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
