11-18-2018, 08:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | Mi 8 account 'dipper' problem mi account error in qc fire , cheked custom loader also, no result log here Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM79) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [E1B00800] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm845_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZG U9ImZhbHNlIiAvPjwvZGF0YT5= Please use correct loader and check USB port / cable. Operation Finished. Sabah Managattupulam |
The Following User Says Thank You to Abussabah For This Useful Post: |
12-22-2018, 16:23 | #2 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Azerbaijan
Member: 622715 Status: Offline Thanks Meter: 82 | same problem Operation : Disable Mi Account Checking for existing devices...Found Port : Android HS-USB QDLoader 9008 (COM14) Driver Info : TCL, qcusbser.sys, 6.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00800 [E1B00800] 00007200 OPK_DATA : 99AF649E077EBCE3E9E187442ABDC70BD715756DE9ED192E9F 7883A10EBE09F4 Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Finished. QcFire Ver. 3.5 |
The Following User Says Thank You to tronuka37693769 For This Useful Post: |
