05-13-2020, 10:11 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: ISTANBUL
Member: 215919 Status: Offline Thanks Meter: 37 | mi 9 se efs problem please help Operation : Wipe EFS (FastBoot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : GetVar Variable Not found Product : grus Bootloader : Unlocked Wiping EFS...Failed Wiping EFS [Method 2]...Done QcFire Ver. 5.5 |
05-13-2020, 19:09 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You can also try in Sideload mode, but only if phone has stock recovery. If sideload mode also does not work, then check if you can do it manually in fastboot mode. Commands are following: fastboot erase modemst1 fastboot erase modemst2 fastboot erase fsg Be warned, no EFS backup can be made in Fastboot mode. So it will not be possible to recovery EFS if anything goes wrong. Br, UMT |
