02-24-2018, 18:19 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Strangest thing! Not possible to kill phone on frp reset. Check frp reset log for fw details amd flash with same. Br, Ultimate Multi Tool |
02-24-2018, 19:54 | #8 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | No! It means either you didnt used QcFire for FRP Reset or you or someone else played with this device. Logs are always saved in Logs folder. Br, Ultimate Multi Tool |
The Following 4 Users Say Thank You to U.M.T For This Useful Post: |
02-24-2018, 20:13 | #9 (permalink) |
Registered User Join Date: May 2017 Location: Spaine
Member: 2716694 Status: Offline Thanks Meter: 13 | here the log bro Operation : Reset FRP Checking for existing devices...Found Port : COM37 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware* : 8953, eMMC, 64 GB Warning! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information... Partition data missing! Resetting FRP Lock......Done Operation Finished. |
02-25-2018, 07:39 | #10 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | This log has no information about Software version, and also its next to impossible to kill phone completely by frp reset. Now only way is to flash with latest firmware available from MI, and for exact model. Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
02-25-2018, 08:24 | #11 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | yes there is no chance to dead completly any mobile by frp in umt in some case , may be restart posible...but dead...i dont think so anyws.. in your case chek battery...chnge firmware... |
04-19-2018, 18:44 | #15 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | I already made several frp xiaomi a1 I had no problem in any of them. http://forum.gsmhosting.com/vbb/13071151-post4469.html if you have the solution leave here in the forum for everyone so if someone else has this problem they will have the solution |
The Following User Says Thank You to bruno santana For This Useful Post: |
