05-07-2018, 16:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | Mi A1 Vibrate only After Erase EFS |
05-07-2018, 17:45 | #2 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | this cell phone withdraw account by clicking reset frp now try writing an EFS http://forum.gsmhosting.com/vbb/13099740-post55.html |
05-07-2018, 18:04 | #3 (permalink) | |
Member: 593876 Status: Offline Thanks Meter: 302 | Quote:
The Following User Says Thank You to mcclinic For This Useful Post: |
05-07-2018, 18:17 | #4 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | [email protected] bruno rodrigues santana |
05-08-2018, 10:11 | #5 (permalink) | |
05-08-2018, 15:27 | #6 (permalink) |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | just flash this file https://mega.nz/#!4IkH3D5B decryption password is !iP9Rt_YGEenXOw85QgFVS-cZQSZlpp7dc3aHpaRmiEM else if above method not work just try bottom method just flash august 2017 firmware in edl mode and then after sucess flash efs if u have efs else write qcn and imei by umt method 1 or 2 tested by me Last edited by owais a; 05-08-2018 at 15:36. Reason: wrong month wrote |
11-18-2018, 16:09 | #7 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2213928 Status: Offline Thanks Meter: 440 | Mi a1 mdi2 after reset frp umt only shows vibrate...?? Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM91) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Mi A1 [msm8953] Software : OPR1.170623.026.V9.5.13.0.ODHMIFA, V9.5.13.0.ODHMIFA [Tue May 22 14:21:02 WIB 2018] Android Ver. : 8.0.0 Patch Level : 2018-05-05 Resetting FRP Lock......Done Operation Finished. Module Ver. 2.0 Mi a1 have 2 power ic 1 pm8940 big power ic 2nd pmi9840 for charging base Usb cancation go in charing ic if in case you short edl point and not remobr battery and flash the phone in same time edl point shorting damage ypure phone pmi8940 ic in this case yourey phone go in only vibert small bit mode so change you're phone pmi9840 ic and enjoy More details chack this https://drive.google.com/drive/mobil...mucia4kZ0Gm0xY Last edited by U.M.T; 12-14-2018 at 12:38. |
The Following User Says Thank You to yuvraj9x2 For This Useful Post: |
