12-05-2018, 14:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: madrid
Member: 2296854 Status: Offline Sonork: 100.1680516 Thanks Meter: 89 | mi max flash issue Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM36) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.8 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8976_002]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8976, eMMC, 128 GB LU Count : 1 [0x0E8F6000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [dummy.img] -> [misc] ...Done Writing [logo.img] -> [logo] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [splash.img] -> [splash] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [persist.img] -> [persist] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img] -> [cache] ...Done Writing [cust.img] -> [cust] ...Done Writing [system.img] -> [system] ...Done Writing [userdata.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 3.4 after this phone not truning on always show 9008 port even i cant flash with mi flashtool.how to solve it????????????????????????? |
12-05-2018, 16:01 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | It seems you have flashed with wrong firmware. You must identify correct firmware for your device and flash it again. Before anything, just try to remove battery and keep Power button pressed to discharge board, then connect battery and try to turn on again, or to put in EDL again. Br, UMT |
12-05-2018, 16:55 | #3 (permalink) | |
Member: 2296854 Status: Offline Sonork: 100.1680516 Thanks Meter: 89 | Quote:
12-05-2018, 19:05 | #6 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | [QUOTE=gmjony;13451722]hydrogen_global_images_V10.1.1.0.NBCMIFI_20181108. 0000.00_7.0_global_2568ea18fc[/QUOTE its maybe wrong firmwere bro http://bigota.d.miui.com/V10.0.1.0.O...6af721a86e.tgz try this |
12-05-2018, 19:17 | #7 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
It helps most of the time to get correct firmware. Br, UMT | |
