08-12-2018, 07:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: india
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | mi note 5 pro mi acount reset problem Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM38) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM38) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 |
08-12-2018, 07:41 | #2 (permalink) |
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM38) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 |
08-12-2018, 07:42 | #3 (permalink) |
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Operation : Reset Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM38) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 |
08-12-2018, 07:43 | #4 (permalink) |
Member: 801212 Status: Offline Sonork: 100.1657902 Thanks Meter: 773 | Operation : Disable Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM38) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8996_016.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 |
08-12-2018, 08:08 | #5 (permalink) | |
No Life Poster Join Date: May 2016 Location: ..:: BHARATH ::.. Age: 34
Member: 2569641 Status: Offline Sonork: WHATS APP & F.B Thanks Meter: 657 | Quote:
