07-13-2018, 03:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: <...< Egypt >...>
Member: 2821459 Status: Offline Thanks Meter: 806 | ... {Xiamo Redmi Note4 Read Firmware&Reset FRP Done By UMT Box} ... ... {Xiamo Redmi Note4 Read Firmware&Reset FRP Done By UMT Box} ... ... {Read Firmware LoG} ... Code: Operation : Read Firmware Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM23) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK USERDATA : Encrypted Reading USERDATA will cause large firmware size and slow read speed. Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20180531213711, V9.5.11.0.NCFMIFA [Thu May 31 21:37:09 WIB 2018] Android Ver. : 7.0 Patch Level : 2018-05-01 Reading [modem]...Done Reading [fsc]...Done Reading [ssd]...Done Reading [sbl1]...Done Reading [sbl1bak]...Done Reading [rpm]...Done Reading [rpmbak]...Done Reading [tz]...Done Reading [tzbak]...Done Reading [devcfg]...Done Reading [devcfgbak]...Done Reading [dsp]...Done Reading [modemst1]...Done Reading [modemst2]...Done Reading [DDR]...Done Reading [fsg]...Done Reading [sec]...Done Reading [splash]...Done Reading [aboot]...Done Reading [abootbak]...Done Reading [boot]...Done Reading [recovery]...Done Reading [devinfo]...Done Reading [system]...Done Reading [cache]...Done Reading [persist]...Done Reading [misc]...Done Reading [keystore]...Done Reading [config]...Done Reading [oem]...Done Reading [limits]...Done Reading [mota]...Done Reading [dip]...Done Reading [mdtp]...Done Reading [syscfg]...Done Reading [mcfg]...Done Reading [lksecapp]...Done Reading [lksecappbak]...Done Reading [cmnlib]...Done Reading [cmnlibbak]...Done Reading [cmnlib64]...Done Reading [cmnlib64bak]...Done Reading [keymaster]...Done Reading [keymasterbak]...Done Reading [apdp]...Done Reading [msadp]...Done Reading [dpo]...Done Reading [cust]...Done Reading [userdata]...Done Reading [gpt_main0]...Done Reading [gpt_back0]...Done Saved to : E:\Gendi\Xiaomi\Xiaomi_Redmi Note 4_AL1512-xxxx-build-20180531213711_2018-05-01\ Operation Finished. ... {Reset FRP LoG} ... Code: Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM23) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-xxxx-build-20180531213711, V9.5.11.0.NCFMIFA [Thu May 31 21:37:09 WIB 2018] Android Ver. : 7.0 Patch Level : 2018-05-01 Resetting FRP Lock......Done Operation Finished. |
The Following User Says Thank You to Elgendi For This Useful Post: |
