11-03-2019, 11:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | MI NOTE5 PRO WHYRED bootloader unlock failed-any other way? Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 [whyred] Software : PKQ1.180904.001, V10.3.2.0.PEIMIXM [Thu Aug 8 17:14:58 WIB 2019] Android Ver. : 9 Patch Level : 2019-08-05 Reading Data...Done Bootloader : Locked Preparing Data...Done Writing Data...Failed Operation Failed. QcFire Ver. 4.8 any other way for bootloader unlock-help me |
11-03-2019, 12:53 | #2 (permalink) |
No Life Poster Join Date: Mar 2017 Location: Muhosransk
Member: 2698409 Status: Offline Thanks Meter: 244 | If you read other success reports and instructions, you will see that it can be unlocked in MIUI 9 (need to find exact firmware). Of course you can't unlock it on any version. Downgrade at your own risk |
11-04-2019, 08:39 | #4 (permalink) | |
No Life Poster Join Date: Mar 2019 Location: saturn
Member: 2901996 Status: Offline Thanks Meter: 917 | Quote:
Write patch file of redmi note 5 pro screenblank but chk pc,should be detect fastboot after write patch file. unlock by fastboot method finally write full stock firmware Regards | |
The Following User Says Thank You to Titan_GSM For This Useful Post: |
11-05-2019, 07:55 | #5 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
Operation : Xiaomi Boot Patch Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 [whyred] Software : PKQ1.180904.001, V10.3.2.0.PEIMIXM [Thu Aug 8 17:14:58 WIB 2019] Android Ver. : 9 Patch Level : 2019-08-05 Processing Redmi_Note5_Pro....Failed Operation Failed. QcFire Ver. 4.9.1 what i do as a next step? | |
