Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-26-2020, 06:23   #1 (permalink)
Member: 818995
Thanks Meter: 75
Need help regarding Nokia 2 Ta- 1011 now device on Diagnostics 900E [Answered]
when i got the device camera problem. after that i flash with umt device automatically goes to the Qualcomm 9008 qdloader port.
after flash the umt .Here is the log.
Device : Nokia TA-1011
Operation : Read Information
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM11)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1009600 [8909] 00000000
OPK_DATA : A57FDEEB0D02233786D8DDCA8A9889D62F92D43EE56EAC9966 024663C39A5B06
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8909_051]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : 8909, eMMC, 8 GB
LU Count : 1 [0x00E90000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : FIH FIH-E1M-FIH [msm8909] [E1M]
Software : 00WW_1_15P, 00WW_1_15P [Thu Oct 11 20:11:59 CST 2018]
Android Ver. : 8.1.0
Patch Level : 2018-10-01
USERDATA : Normal
You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss.
Operation Finished.
QcFire Ver. 4.5
Now device on Diagnostics 900E How to recover from This problem ?
Old 05-26-2020, 06:53   #2 (permalink)
Unlockinfo's Avatar
Member: 1785930
Sonork: 100.1685640
Thanks Meter: 4,780
Opening Port...OK
USERDATA : Normal
Operation Finished.
QcFire Ver. 4.5
https://i.postimg.cc/ZnTwXFKv/Diagnostics.png
If You Have backup then restore backup other wise downlaod xml latest version and flash again,
Br,
Unlockinfo
Old 05-26-2020, 07:03   #3 (permalink)
Member: 818995
Thanks Meter: 75
Br,
Unlockinfo
The thing is device is now on Diagnostics 900E . how to put this device on Qualcomm 9008 qdloader ?
Old 05-26-2020, 15:52   #4 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,431
Which firmware you used to flash phone?
It seems you flashed wrong firmware. Please post log of flashing and also Read Info log before flashed it.
Br,
UMT
Old 05-26-2020, 16:12   #5 (permalink)
Member: 818995
Thanks Meter: 75
Br,
UMT
i committed my mistake i flashed wrong firmware. But the thing is how to recover from Diagnostics 900E ports to Qdloader9008 port. please help me Respected
Old 05-27-2020, 19:14   #6 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
simply disconnect battery and connect testpoint ..keep trying untill it shows qualcomm 9008 port
Old 05-28-2020, 21:57   #7 (permalink)
U.M.T's Avatar
Member: 2465108
You can do a Quick Google Search to find it.
Btw, you must disassemble phone.
Br,
UMT
Old 05-29-2020, 02:45   #8 (permalink)
Member: 818995
Thanks Meter: 75
Hello Respected's can i have umt reader firmware of nokia Ta-1011 Android 8. please give the link.
Old 06-28-2020, 14:25   #9 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
i have same issue on nokia 2 ta-1011 ..try to flash with flash tool but flashing failed and after this phone is dead and its connect to pc in 9008 mode always without shorting any test point
so how to exit this hs usb diagnostics 9008 port mode ?
Page generated in 0.17874 seconds with 8 queries
