05-25-2020, 22:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Dominican Republic Age: 35
Member: 1078865 Status: Offline Sonork: 100.1626549 Thanks Meter: 83 | Need loader for flash ZTE Z755 Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM99) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.8.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1108100 [8x26] 04000400 OPK_DATA : A73B09776FFC7672832960646DFE2F1524AB6B799F813BF9C5 91715A53DDFC73 Initializing Protocol...OK Using Auto Loader Selection [4] No compatible loader found. Device may not boot with this loader. Preparing Loader...Done Sending Loader [8x26]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTk5KT == Using Alternate Method... DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTk5KT == Error getting Payload Information! Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTk5KT == Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.0 |
05-26-2020, 07:08 | #2 (permalink) |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | if you have official xml firmware then select manual loader file, if you have not a firmware then find Br, Unlockinfo |
The Following User Says Thank You to Unlockinfo For This Useful Post: |
