07-11-2019, 10:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | one plus a2003 frp not reset plz help use all model also same message Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009400 [8994] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8994]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.4 |
07-11-2019, 14:27 | #2 (permalink) | |
Product Supporter Join Date: Sep 2016 Location: Pakistan
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | Quote:
07-11-2019, 14:35 | #3 (permalink) |
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | Also Use This Loader And Post Result https://drive.google.com/file/d/1pkI...Ff1Sr8s96/view |
07-13-2019, 10:59 | #5 (permalink) | |
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | chek this plz Quote:
Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009400 [8994] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8994]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.3 | |
07-13-2019, 11:17 | #7 (permalink) | |
