05-26-2020, 05:37 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: india
Member: 905341 Status: Offline Thanks Meter: 998 | Power off the phone. Plug in the USB cable your computer but do not connect the other end to the phone. Hold down Volume Up and Volume Down buttons for a few seconds, and plug in the cable while you are continuing to hold them. You should see the anticipated EDL mode. |
05-26-2020, 10:56 | #4 (permalink) |
Insane Poster Join Date: May 2004 Location: росс&# Age: 47
Member: 66638 Status: Offline Thanks Meter: 4 | Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 85495100 OPK_DATA : 7A44FD44C35394DC10E1B910D525491DA862D0E420FE0BEF04 0FECF30032DA08 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SD855]...Done Executing Loader...OK Detecting Chip Type...OK DebugData : BAAAABAAAAANAAAAAQAAAA== Using Alternate Method... DebugData : BAAAABAAAAANAAAAAQAAAA== Error getting Payload Information! Error Log : BAAAABAAAAANAAAAAQAAAA== Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.6 how do i unlock device |
05-26-2020, 17:36 | #6 (permalink) |
Member: 66638 Status: Offline Thanks Meter: 4 | Device : OnePlus 7 Pro Operation : Reset Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM5) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 85495100 OPK_DATA : 7A44FD44C35394DC10E1B910D525491DA862D0E420FE0BEF04 0FECF30032DA08 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SD855]...Done Executing Loader...OK Using User Defined Storage Type : UFS Hardware : SD855, UFS, 256 GB LU Count : 6 [0x03A90800] [0x00000800] [0x00000800] [0x00002000] [0x00100000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 1048576, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : OnePlus [OnePlus7ProTMO] Software : , 1905021004 [Thu May 2 10:23:16 CST 2019] Android Ver. : 9 Patch Level : 2019-03-01 USERDATA : Encrypted Encrypted USERDATA is NOT SUPPORTED Use [Disable Locks] function for Encrypted Userdata Operation Finished. QcFire Ver. 5.6 what to do? Encrypted USERDATA is NOT SUPPORTED? |
05-27-2020, 22:44 | #7 (permalink) | |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | Quote:
