10-07-2018, 09:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: pakistan
Member: 1083358 Status: Offline Thanks Meter: 199 | Oppo A53 Reset lock log Operation : Reset Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM55) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B09000 [8936] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8936_036]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8936, eMMC, 16 GB LU Count : 1 [0x01D5C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO OPPO A53 [msm8916] Software : A53_11_A.11_160627, eng.root.20160627.205258 [Mon Jun 27 20:55:15 CST 2016] Android Ver. : 5.1.1 Patch Level : 2015-10-01 USERDATA : Normal Resetting Google Locks... Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block Failed Read EXT4 Block FailedFailed Operation Failed. QcFire Ver. 2.9 now only qualcom usb loader 9008 |
