09-06-2018, 09:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: nakodar
Member: 903492 Status: Offline Sonork: 1590666 Thanks Meter: 571 | Oppo A71 (CPH1801) formet problem Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM23) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_015]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.7 |
09-06-2018, 16:07 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Please try with 2.6, it should be OK. If not, please let us know. QcFire v2.6 is available on Support and Mirrors as well. Br, UMT |
10-18-2018, 10:59 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Possible that Oppo updated device via OTA and it does not accept old loader. And if this is the case, then better to forget it for time being. Br, UMT |
