03-22-2018, 07:23 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: ONLY WITH YOU Age: 39
Member: 314847 Status: Offline Thanks Meter: 102 | OPPO A71 CPH1801 Pattern remove BY UMT [Success Report] Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM105) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_015.ufl]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. Module Ver. 2.0 |
The Following 7 Users Say Thank You to utsav_jayesh For This Useful Post: |
04-02-2018, 08:57 | #4 (permalink) |
Registered User Join Date: Apr 2015 Location: pleiku
Member: 2382850 Status: Offline Thanks Meter: 111 | hihi click unistall (driver qualcom cm2) tick delete remove driver restart pc setup driver QDLoader HS-USB Driver_64bit_Setup QDLoader HS-USB Driver_32bit_Setup test done |
05-21-2018, 07:35 | #5 (permalink) |
Junior Member Join Date: May 2010 Location: Locknow
Member: 1295329 Status: Offline Thanks Meter: 0 | OPPO 1801 Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM16) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_015.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : Unknown, Unknown, ERASED GPT Payload Info : In: 262144 [512], Out: 512, Sector Size: 512 Reading Partition Table...OK SYSTEM partition is missing! Partition data missing! Operation Failed. Module Ver. 2.0 |
05-21-2018, 08:13 | #6 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
07-03-2018, 06:19 | #7 (permalink) |
No Life Poster Join Date: May 2016 Location: ...:::cAtCh mE iF U cAn:::...
Member: 2570477 Status: Offline Thanks Meter: 427 | Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM461) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_015.ufl]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. Module Ver. 2.4 |
07-03-2018, 10:25 | #8 (permalink) |
Freak Poster Join Date: Jun 2009 Location: INDIA
Member: 1050364 Status: Offline Thanks Meter: 162 | Oppo A71 (CPH1801) FORMAD DONE FRP NOT REMOVE Device : Oppo A71 (CPH1801) Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM21) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_015.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : Unknown, Unknown, ERASED GPT WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [512], Out: 512, Sector Size: 512 Reading Partition Table...OK SYSTEM partition is missing! Resetting FRP Lock...Failed Operation Failed. Module Ver. 2.4 |
07-04-2018, 06:00 | #11 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: Punjab Age: 29
Member: 2559593 Status: Offline Thanks Meter: 75 | Quote:
for frp use *#812# in emergency calling and after remove frp just simply change language and reset your phone again... | |
The Following 2 Users Say Thank You to JatinderRangra For This Useful Post: |
08-11-2018, 18:25 | #12 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1801 Pinlock Format Code: Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM154) Driver Info : Qualcomm Incorporated, qcusbser.sys, 6.0.5.4 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_015.ufl]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. |
08-12-2018, 08:46 | #13 (permalink) |
No Life Poster Join Date: May 2016 Location: ..:: BHARATH ::.. Age: 34
Member: 2569641 Status: Offline Sonork: WHATS APP & F.B Thanks Meter: 657 | Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 74CBAEF3BA268ADE2E3358EFC3D2CA99C340596C0C7F14E283 D91F76E0EA3DFE Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Firehose Loader...Done Sending Loader [8953_009.ufl]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 |
