02-25-2021, 15:40 | #1 (permalink) | |
Freak Poster Join Date: May 2015 Location: Chittagong
Member: 2397029 Status: Offline Thanks Meter: 52 | Pls help redmi 6A Connect BROM failed: STATUS_SEC_AUTH_FILE_NEEDED redmi 6A Connect BROM failed: STATUS_SEC_AUTH_FILE_NEEDED Quote:
02-25-2021, 17:57 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Use 3.8 from support - Disable Auth - Select Model - Mi Account Reset or Format FS Br, UMT |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
02-25-2021, 20:01 | #4 (permalink) |
Freak Poster Join Date: Oct 2012 Location: transilvania
Member: 1820429 Status: Offline Thanks Meter: 57 | Brand : Xiaomi Model : Redmi 6A Operation : Read Info Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8] |
02-26-2021, 04:31 | #6 (permalink) | |
Member: 1820429 Status: Offline Thanks Meter: 57 | Quote:
Operation: Disable Auth Waiting for device in BROM mode... Port: COM36 Port Name: MediaTek USB Port (COM36) Path: \\?\usb#vid_0e8d&pid_0003#6&36559b33&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Read Failed! [UltimateMTK Ver. 3.8] | |
02-26-2021, 15:12 | #8 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | without results Operation: Disable Auth Waiting for device in BROM mode... Port: COM36 Port Name: MediaTek USB Port (COM36) Path: \\?\usb#vid_0e8d&pid_0003#6&36559b33&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Read Failed! [UltimateMTK Ver. 3.8] after this I leave it connected, it is still connected to the mtk port, I deactivate it and this happens Operation: Disable Auth Waiting for device in BROM mode... Device not found, timeout! [UltimateMTK Ver. 3.8] Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8] |
02-27-2021, 03:45 | #10 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM36) Connect BROM failed: STATUS_ERR(-1073676287) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8] help me |
